Question about Port Incorporated 2007-2010 Honda CR-V Receiver 4XN0
Screeching sound from left rear wheel when driving only in honda crv 2007
Screeching sound from left rear wheel when driving.The sound disappears when the vehicle stops.
Intermittant screeching noise by rear passenger side
Your description makes me worry. If you have a strange, unknown screeching noise coming from the right rear wheel and now there is a burning smell. Please stop using it and have it looked at as soon as possible. There are a few things that could be the cause of these symptoms. Wheel bearing failure, seized brake caliper or frozen caliper sliders, damaged brake line, seized E-brake cable, or improperly installed brake-pads. In any case, if you continue to drive this car, with these symptoms. You may cause a break-down (requiring a tow), or cause a fire. Let me know if I can answer any other questions or how the repair goes, good luck.
Apr 01, 2014 | 2005 Chevrolet Malibu Maxx
2006 Honda CRV makes screeching sound while turning corners
built into the brake pads is a small bit of metal that when the pads get to low to be safe , runs on the rotor and produces the squeal applying the brakes stops the vibration so the noise drops off
Jun 29, 2017 | 2006 Honda CR-V
1999 Ford Explorer 4wd. Screeching at all 4 tires
Is it full time four wheel drive? could ot be stick in 4X4 as this will make nasty noises unless dead straight.
Apr 26, 2010 | 1999 Ford Explorer
My 2005 rmz 450 makes a screeching sound when i give it throttle what could cause this thanks
About the only thing that would cause a screeching sound in the engine is bad crank bearings or a bad sprocket shaft bearing. A bad bearing in the rear wheel can screech as well. Just be sure where the screech is coming from.
Oct 23, 2009 | 2005 Suzuki RM-Z 450
2007 crv noise when turning steering wheel right or left
it sounds like rear differential noise does the rear end feel binding? if so you req the diff to be flushed twice there is a set procedure for this
Oct 07, 2009 | 2007 Honda CR-V
Screeching noise
bad brakes grinding against the rotors, or a bad wheel bearing.
Aug 06, 2009 | 1996 Honda Civic
Screeching noise
If your C/V joint is going bad it will make a nasty clicking sound and get louder the longer you leave it unattended.If this noise went away it could have been something stuck it the moving area of your wheel and just worked itself out.Keep an ear out for the noise to return,it it dosen't come back be happy.
Jul 23, 2009 | 1996 Honda Civic
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Port Incorporated 2007-2010 Honda CR-V Receiver 4XN0 Logo
12 people viewed this question
Top Port Incorporated Car Audio & Video Experts
xxxxxx xxx
Are you a Port Incorporated Car Audio and Video Expert? Answer questions, earn points and help others
