Question about Hoover Platinum LiNX Cordless Stick Vacuum
Hoover linx battery, Not sure if my problem is the battery the charger or the vacuum itself.
The unit worked fine, when the battery ran down I placed it on the charger for an entire day but when I replaced the battery the vacuum would not turn on. My chargers blue light continually blinks whether the battery is in it or not (I never paid much attention, so not sure if that is normal or not). I have no way to test the battery and I don't want to spend the $$ purchasing a replacement if it is the charger or the unit itself. Any help would be greatly appreciated. Thanks in advance.
    Top Expert:
  • Hoover Master
  • 41,889 Answers
Probably the battery is defective and doesn't recharge.
Posted on May 29, 2017
Buffalo12980
  • 625 Answers
SOURCE: Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Posted on Sep 22, 2007
reddevil6
  • 1673 Answers
SOURCE: hoover floormate
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Posted on Feb 29, 2008
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
SOURCE: battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Posted on Aug 19, 2009
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Posted on Apr 29, 2010
Should battery stay on charger after it is charged between use. This is for a Hoover Linx cordless vacuum
I leave mine on the charger until I use it mostly more than 8 hours after charged and in 12 months nothing has happened
that is why the charger is incorporated into the stand
Dec 29, 2017 | Hoover Vacuums
Why doesn't the brush roller rotate?
Hi, this is Jim with Crucial Vacuum,
The belt may not be broken, but it may be lacking in tension and therefore unable to rotate the brush roll on its own. You're going to want to replace your vacuums belt every 3 to 6 months depending on usage. Check to see if the belt is loose, or over stretched.
Check the brush roll as well and be sure its securely locked into place. It could be slightly loose causing a lack of communication between itself and the belt. Our video can help with fitting the belt in properly with the brush roll:
https://www.youtube.com/watch?v=LRV8280PQxc
You can purchase replacement belts and brush rolls for your Hoover Linx directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-linx-platinum-roller-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 05, 2015 | Hoover Platinum LiNX Cordless Stick Vacuum
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover linx
How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
Jul 02, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover linx brush motor
Locate the dimple somewhere around the edge of the two components to be separated.
Put a sheet or drop-cloth down and work on that to prevent anything from being lost if it opens suddenly. (it should be fine).
Use a large flat head screwdriver to pry it open.
Feb 06, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover linx battery, charger or unit itself?
As a former owner of one, my suggestion is that it be discarded rather than repaired.
Jan 01, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover Platinum LiNX Cordless Stick Vacuum Logo
368 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
