Question about Hitachi 15.5 Cu.ft RZ440 Top Mount Refrigerator FOR 220 VOLTS
Do I remove the water tank behind the fridge - Hitachi 15.5 Cu.ft RZ440 Top Mount Refrigerator FOR 220 VOLTS
My water dispenser is not working properly. It starts out with a good flow, then immediately slows down to a trickle. It started this after I replaced my filter. I removed the filter and tried the...
Hello, Thank You for using FixYa. I will be helping you today.Have you changed your water filter?If you have one it will be inside the fridge or on bottom in the front. This also happens when the water pressure is to low going to the unit from the house. If all those are ok make sure the tank in the fridge behind the drawers is not frozen,You can use a hair dryer to thaw out the tank
Thank You and please rate my answer if it was helpful...
Jun 22, 2011 | Whirlpool Refrigerators
Freezer temp is -4 and refrig is 38. Not sure if these are correct settings but water in freig bladder keeps freezing and can't get water. Warmed bladder twice to get water to come out. If freezer temp...
Sorry if you don't like this solution, it does not make it work correctly. But my water works all the time now.
We too had the water dispensor stopping due to freezing of water in the storage tank. A blow dryer and about 10 minutes later we could get it working again.
We tried different fridge temp settings , and according to a thermometer placed inside the fridge in various locations we are getting the fridge temps we want, so it is not runing too cold.
I tried insulating the storage tank and the lines, this did not work.
I removed the tank and just connected the two lines, this still did not work.
I finally just pulled the lines out of the fridge completely and connected them underneath the fridge so water runs from the valve at back straight to door. The plastic panel on bottom was a great place to store the lines. I drilled a hole to reroute the door line to this area . Line runs behind lower plastic cover on front . The water does not get cold, but it never stops flowing, this was more important to us. I did consider rerouting both lines to the top shelf and putting the storage tank back in to get colder water, but no one minds the way it works so I probably will not do this. I would have run them up the back to avoid the inside lower area of the fridge. In the long run I will avoid this brand and avoid "twin-cooling" completely. All my neighbors and friends who bought this type all had to throw them away as they were too dofficult and expensive to keep running.
Jan 15, 2011 | Samsung RS2534 Side by Side Refrigerator
Fridge is not cooling down. Freezer is fine only the fridge. Plus the water dispenser - water is not that cold
These units like most fridge/freezers, actually cool the freezer first, then a damper opens that flows freezer air into the fridge side cooling it. The thermostat/switch controls the freezer, the refrigerator is controlled with a damper. The cold water storage tank is usually hidden in the bottom rear of the fridge, behind the vegetable bins, so if the fridge is not cold the H20 is also warm. I suggest you unplug the fridge, empty the freezer and remove the covers. Your issue could be a simple ice blockage of the air passage, or a stuck or broken damper control. Use Sears parts to look up a exploded view of your fridge. At minimum, you will learn a bit, and if you end up calling a service guy, he will know he cannot fool you and overcharge you.
Jan 08, 2011 | Cuisinart Private Reserve CWC-600 Wine...
No drinking water and lots of ice around the back panel in the fridge (which we couldn't get off despite lots of effort). Also, plastic curved tube where water comes in is frozen. I keep fridge at the...
Yep, This sounds like a freezing problem, there is a water tank heater and a water line heater in the system, The tank heater is located behind the panel that the tank is mounted to. there is also a heater fuse in the circuit behind the panel. you will need to us a heat gun or blow dryer to defrost and check somethings back there. I saw someone selling a repair service manual on the online auction place E b a y that may help you further troubleshoot the problem.
Dec 11, 2010 | Samsung RS2534 Side by Side Refrigerator
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Water in carpartment under fridge.
thats the dispensor tank, is there a drip pan under neath the refrigerator?
Apr 24, 2010 | GE GSH25JFR Side by Side Refrigerator
Water dispensing
they do have a water tank freeze up kit for that exact issue
Feb 14, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
Hitachi 15.5 Cu.ft RZ440 Top Mount Refrigerator FOR 220 VOLTS Logo
15 people viewed this question
Top Hitachi Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Hitachi Refrigerator Expert? Answer questions, earn points and help others
