Question about Ebac Dehumidifiers
Wont restart after emptying water
Wont restart
Is it possible to buy a portable dehumidifier which will automatically restart and function after a temporary power outage? What do you ask for?
Hello William, thank you for your post!
I understand that you would like to have a dehumidifier that restarts after a power outage. I have reviewed the available models for Frigidaire and show that feature is not available. You may want to speak with additional manufacturers for that feature. I hope this information is helpful to you. -Matt
Mar 20, 2016 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Why does the power light on my dehumidifier flash quickly?
without the model number I cant be 100% sure , but due to your description of the last thing u did , Id say the light is flashing indicating that the water catch bucket is not installed correctly back as it was before , most units have a safety that wont allow a unit to operate unless the water catch bucket is installed and M/T as this would allow it to dump water to the floor if it were not
Nov 24, 2015 | Dehumidifiers
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
My des12 red light wont go off although unit is empty of water
Again!!!! Unplug machine X 15 minutes. Then fill with water. Then plug back in! If still lit, you have a water scale (mineral build up) issue that needs cleaning according to owners manual
Jan 19, 2014 | DeLonghi DE500 Dehumidifier
The float is broken in our dehumidifier, is it repairable?
Is the float in the empty or full position?? If it is in the empty position, and the unit will run normally, then yes you can. The water will divert from the evap tray right into the hose. If it is stuck in the full position, and wont run because it thinks it's full, you will have to find a way to put and hold it in the empty position.
Nov 10, 2013 | Danby DDR600R Silhouette Dehumidifier
After unplugging, we moved the system across the room and can"t get it to come back on.
Unplug it for 5 minutes then restart it. A compressor needs 2 minutes to equalize pressures before attempting to restart.
Check that your outlet has power.
Gary
Sep 05, 2011 | Haier 45-Pint Dehumidifier
My dehumidifier wont turn back on. I emptied the water and it says CH 01. What does this mean?
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 05, 2011 | LG Dehumidifiers
Dehumidifiers Logo
24 people viewed this question
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
Gil Shultz
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
