Question about Homelite 'Yard Broom' Leaf Blower
Willnot start my blower will not start even after i changed the sparkplug what do you recommend
  • 323 Answers
How long has it been since you've used the blower? Often people leave old gas and oil mixed for 2 cycle engines over the winter or for long periods of time and it can congeal or gel and form a real mess in the carb, so that either the sparkplug is filled with a gummy substance or the fuel bowl/lines are so gummed up, only a messy residue gets to the spark plug.
When this happens I first pour all the old gas out of the tank, and use the primer to push what is in the lines through to the carb bowl. Take the air cover off the carb and spray down inside it with carb cleaner. You don't want to have a new spark plug in there when doing this. All sorts of **** will run out. Now is a good time to either clean the air cleaner or replace it.
Then mix a fresh can of gas and oil in the recommended ratio, and pour about a third of a tank into your gas tank. With the air cleaner still off, pump the primer bulb until you smell the fresh gas coming through the carb. One more time, spray the carb liberally with carb cleaner and pump on the primer again to be certain all the old gas is out of the tank and carb.
Now is the time to remove the old spark plug and pull the cord a few times to wash out the cylinder head and the top of the piston.
Properly gap a new plug and, giving the head time to dry out, screw it in place. Leave the air cleaner off at this point. Take starting fluid and give it a small shot. Crank the blower with the rope. It make take several times, and at first it will only run on the starter fluid and then die. Eventually you will have the fresh gas in there and it will run on its own. After its warmed up, and you can shut it off and start it without the starter fluid, put the new air cleaner on and prepare to blow everything away!
Posted on May 20, 2009
  • 1,869 Answers
Check and,or; replace your fuel filter
How to change fan blade BV1000
Hi Geno,
I have the same problem. Reading previous answers it seems we need to remove the sparkplug, insert a bit of rope gently in to block the motor and once blocked the nut on the fan/impeller can be undone.
I'm going to give this a try on mine. Recommend we both proceed with caution, mate!
Feb 24, 2012 | Black & Decker & Leaf Hog Blower / Vacuum
Snowblower won't start, changed gas and sparkplug
remove carburator bowl and clean(may need to clean float needle too). reassemble and test. also make sure you are getting a spark.
let us know if you have more problems.
Feb 09, 2011 | Toro Snow Blower Scraper For S200 s620 New...
I've put a new sparkplug and new filter -but the blower won't start . Doesn't even feel like it wants to start
Put a spoon full of gasoline straight down the plug hole. Reinstall the plug, if it starts then you obviously have a fuel problem. You may need a new kit installed in the carburetor. Easy fix.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
Husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Oct 21, 2009 | Husqvarna Forest & Garden 125bt Backpack...
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
How to check for spark on leaf blower ?
hi
ground the sparkplug at the cilinder and pull the rope.see if there is a spark.if not try changing the sparkplug
Sep 23, 2009 | Craftsman 4 Cycle Blower/Vac
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Homelite 'Yard Broom' Leaf Blower Logo
641 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
