Question about Shuttle Computers & Internet
Need manual for FIC motherboard AM37-l - Shuttle Computers & Internet
2 Suggested Answers
SOURCE: fic am37 manual
I found exactly what I was looking for at this link, ftp://ftp.fic.com.tw/motherboard/manual/socketa/am37
Posted on Feb 22, 2009
Network driver AM37
Hello here is the fic download page:
http://www.fic.com.tw/download/motherboards.aspx
The model of your mainboard is not to be found here.
But the mainboard was fitted in this pc here:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1427
Try to download the LAN driver, but please unzip the file before you install.
If the driver is not working, visit the PC homepage (not the mainboard) for downloading the driver.
Best of luck
Apr 14, 2013 | Cornerstone FIC AM37-L Socket A XP...
Start button would not respond plug disconected unsure were it goes e machine c 1940
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
You want a Front Panel header pinout.
(See? Know you can go around, and brag to your friends!
"So,......mrcat_grave,.........do you know what a Front panel header is? What about a Front Panel header pinout? How about you Sally?"
Lol! )
Hmmm, I do not find an eMachines C1940 desktop computer.
Could this be an eMachines C1904, or S1940 desktop computer?
If so they both use an FIC AM37 motherboard,
(First International Computer, { Inc } AM37 is the model number of the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07941&lc=en
(Scroll down for Motherboard Layout illustration, and Motherboard Photo )
Provided I am on the right track;
Motherboard installed in computer case:
Processor to the Top, Ram Memory slots to the Right, white long PCI slots to the Bottom;
The Front Panel header is at the Bottom/Right corner.
It is rectangular in shape, and situated Vertically.
Two columns of contact pins.
There are 4 pins on the Left side, 5 pins on the Right side.
(Do NOT get it mixed up with the IR header above it. 6 pins)
The pins are numbered EVEN on the Left side.
The pins are numbered ODD on the Right side.
Starting on the BOTTOM of the Left side, going towards the Top;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the Bottom of the Right side, going towards the Top;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
[LED = Light Emitting Diode ]
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C.
Not Connected. Probably a 5 Volt power source, used by the factory to test with.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Zip file PDF motherboard manual, for the FIC AM37 motherboard.
There is a version 1, and a version 2.
FIC AM37 v1, and FIC AM37 v2.
Doesn't matter which one you choose, as far as the Front Panel header pinout info is concerned.
You may however need info that is in the version 1, or is in the version 2.
You can download both.
Zip file. A compressed file used to send large amounts of information, more easily.
It needs to be decompressed, or 'unzipped'.
You have Winzip on your computer. It is an 'unzip' program.
If it is out of trial time, or not usable, suggest you download, and install the free 7-Zip.
Let's use the AM37 v1 manual as an example;
After you click on AM37 v1, a small window will come up on the right-
Opening am37_v1_manual.zip
Make SURE there is a Green dot, in the small circle to the left of Save File.
If not; click in the empty circle to the left of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this small Download Window.
Then DOUBLE-click right on the file name.
In the next window go to the far left, and click on - Extract all files
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last window DOUBLE-click right on the file name.
(It is next to the red Adobe PDF icon)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | E-Machines Computers & Internet
Wiring diagram emachine w2047 motherboard
The eMachines W2047 desktop computer uses an FIC AM37 mobo.
(MOtherBOard)
FIC is First International Computer, Inc.
This link takes you to a page to download the Motherboard Manual, for the FIC AM37 mobo,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
There is a version 1, and version 2 of the AM37 motherboards.
[ FIC AM37v1, and FIC AM37v2 ]
Click on the appropriate file name, or click, and download both of them. (One at a time)
These are PDF files.
The computer you are on now has Adobe Reader on it, which uses PDF files.
(All you have to do is left-click on the file name)
I would also suggest upgrading to Adobe Reader 9.3.4. ,if you don't have it already.
Give the file time to download. It may take up to 30 seconds before you see the first page.
It may also take additional time for the file to fully download.
Would appreciate it if you would rate my solution if it has helped you.
Post additional questions in a Comment.
Oct 05, 2010 | Computers & Internet
Where can i get a hook up spec on a am37 motherboard .
Do you mean as specific as specifications can get? If so, I was able to retrieve a pdf technical doc for am37. reply to this post to confirm.
Sep 18, 2010 | FIC AM 37 Motherboard
Jumper settings
Thanks for the link you posted, helped me a lot. I had to exclude am37_a0_eng.zip from the link to make it work.ftp://ftp.fic.com.tw/motherboard/manual/socketa/am37
Mar 07, 2010 | Cornerstone FIC AM37-L Socket A XP...
Will processor amd 3000+ work in motherboard am37L
Hi
Thank you for you query
Unfortunatley the maximun this motherboard will support is 2600+
If this has been useful please leave positive feedback/vote/testimonial - Thank you again
Feb 14, 2010 | Cornerstone FIC AM37-L Socket A XP...
Am37 motherboard
What the name of your tower
Aug 28, 2008 | FIC AM 37 Motherboard
Power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
May 10, 2008 | E-Machines eMachines Desktop PC
Fic am37 manual
Sep 03, 2007 | FIC AM 37 Motherboard
Computers & Internet Logo
61 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
