Question about iPhone Apps
Bt vision problems
Since yesterday we have had no picture only the box keeps going through a cycle where there is a blue line then a red circle then a yellow circle then nothing.
  • 103 Answers
SOURCE: Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Posted on Mar 22, 2007
  • 375 Answers
SOURCE: - All Songs Cheat Code? Rock Band.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You might be playing the rythm a tad off. Try to keep it at the same pace pretty quickly without stumbling.
The rythm should be pretty quick. Like eighth notes or sixteenth notes if you're musica
Posted on Jul 20, 2008
CrazyLarry
  • 173 Answers
SOURCE: Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Posted on Nov 10, 2008
SOURCE: blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Posted on Jan 23, 2009
ipodslinger
  • 688 Answers
SOURCE: blackberry wont work box circle square triangle keep popping and wont go to main screen
the 507 error refers to no operating system on your phone.
here is the solution.
open the desktop manager and go to application loader.
and reinstall all the software you have in your apps loader.
if you have never used blackberry desktop manager you can go to blackberry.com
and download it for free. then install the software.
you may need to install the usb drivers also get those there also.
then download the latest version firmware for your phone which you will find on the site also.
depending on your provider and what phone you have.
once you have all that and it's installed, plug your phone in with a usb cord to your computer and reinstall the software through the desktop manager and app loader.
if you have any problems let me know and I will hook you up
Posted on May 23, 2009
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Btbt com help btvision
BT Vision uses Freeview plus catch up TV. Freeview requires a retune because they are making way for new channels. Retune the DTV part or your BT Vision box.
Sep 05, 2014 | Televison & Video
Why do's my bt vision box keeps rebooting its self
It sounds like it has a fault. Contact BT for a replacement.
It might be worth trying the following first: Restarting the BT Vision box Help BT com Help
Mar 03, 2014 | Apple Find My iPhone
BT Vision box re-booting
It sounds that the upgrade was not success. Contact any service technician. google.com/+GopakumarGopalan
Nov 25, 2013 | Toshiba 32AV500U 32 in. LCD HDTV
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
iPhone Apps Logo
65 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
