Question about Exercise & Fitness
Need a user manual for a Healthstream euphoria 3000t treadmill
Where do I find a manual for a evo8000 healthstream treadmill?
www.manualsonline.com
If you wish to get some details ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 31, 2016 | Exercise & Fitness
Want to download a manual for the healthstream GS1180T
Your model doesn't seem to be listed on the manufacturer's website. Contact them directly for additional support.
http://www.healthstream.com.tw/index.php?act=contact
Feb 24, 2015 | Exercise & Fitness
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Healthstream GS1165T treadmill, where do I have to lubricate it, i have lost the manual
see the video and proceed according. lube the rollers bearing front+back +drive belt motor test , and replace the belt if necessary.\\God bles you
Jul 05, 2013 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
Owner manual for Impuls T790 Treadmill
Hope this is what you need.http://www.healthstream.com.tw/upload/2011/01/20110128111522.pdf
Sep 15, 2011 | Nordic Track Nordictrack Exp 1000...
I have a Healthstream Ge3400 Lightning treadmill and I need to know how to tighten the belt as I can't find the user manual for it, It has been ages since it has been used and when you walk on it even...
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt
Sep 04, 2011 | Exercise & Fitness
How can fix my healthstream LS720T treadmill? my healthstream LS720T treadmill after i turn it on it slowly run then it will go faster then stop and will indicate error message E1, what is wrong with it?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Jul 30, 2010 | Exercise & Fitness
Would like a operating manul for :magellan roadmate#3000T
You Could download the same from :-
http://safemanuals.com/user-guide-instructions-owner-manual/MAGELLAN/3000T-_E
Click on Download the Complete User Guide on Right Hand Side.You need to Have Acrobat Reader to View Guide.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 07, 2010 | Magellan RoadMate 3000T GPS Receiver
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
