Question about SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
I bought a small alloy helicopter and it won't respond to the remote control on any of the channels and it is fully chargesuggestions as d, any to what to do?
4 Suggested Answers
lock123
  • 6831 Answers
SOURCE: Batteries installed - charged as
Hello
I have the exact same model you are having problems with. Just a few questions to clarify:
Does the red light flicker in on the circuit?
Also, is the remote turned on?
Let me know about the above described. I will come back top you as soon as possible.
Kind regards
Lock123
Posted on Dec 14, 2010
SOURCE: Bought a S108 helicopter. Charged
There should be a sticker near the helicopters "on off" switch that has an "A" "B" or "C" on it. Make sure the switch on the controller is set to correspond with that letter. If that isnt it, keep it for parts and buy another. These are VERY delicate toys and most break quite easily.
Posted on Feb 18, 2011
SOURCE: The helicopter syma s032 not
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Posted on Sep 13, 2011
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
Syma s031
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
Just purhased two Tier-One Gallant helicopters. They say they are 3 channel. I see no channel selectors on remote or helicopter. I want to fly two of them but don't think I'll be able to unless I have them...
You cannot easily change the frequency these helicopters operate on, they are not designed for multi channel use. To change their operating frequency you would need to find and replace the small crystal inside the helicopter and also inside the remote control.
The 3 channel you are referring to is the number of functions (channels) you can control on the helicopter, not it's frequency channel.
Dec 31, 2013 | Air Hogs Havoc Heli Helicopters
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
I bought rc helicopter of alloy king and i dont know how to make it start.
Insert the batteries into the battery slots in both the controller and the helicopter.now you will be able to control the rc helicopter whenever you want by just switching on the remote control for the device.
May 10, 2011 | Toys
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New...
try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
Dec 27, 2010 | xheli 3 Ch Syma S006 Alloy Shark RC Remote...
The helicopter will not synchronize and I can't get it to communicate with the remote.
Press the throttle up and and back down and hold down a few times, sometimes it help to move left right knobs also. Try on each channel to get it synced
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
I brought a new syma s006 alooy shark rc heli and
Your should exchange the product at the store you bought it from for another one. the problem lies inside the syma. it must have been a defect that the company did not notice.
May 09, 2010 | SYMA Toys industrial Syma S006 Alloy Shark...
SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
