Question about Denon AVR-1312 5.1-Ch A/V Home Theater w/ 3D
Blinking red light on denon avr-1312
When on button is pressed, the red light is blinking
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • 99 Answers
SOURCE: Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Posted on Jul 27, 2010
How do i reset denon avr -1312 receiver
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by brand name to your Device.
Sep 25, 2014 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
Can I get audio out on a denon avr-1312
what are you wanting to audio out to? the AVR is the audio component of a setup so am unsure as to why you would want to
Feb 27, 2014 | Denon AVR 1312
Denon troubleshooting
my denon s900w is blinking on and off. what do to fix the problem
Jan 03, 2014 | Televison & Video
My Boston Acustic subwoofer connected to my Denon Avr 1312 is not turning on the les light on back of subwoofer dobt even come on had fuse checked but its not blown.
There is a common problem with a zener diode in that amp that goes bad. ZD3 is a 18v zener and it goes short. Sometimes R9 on the back will open when this happens. Need to have them replaced.
Oct 09, 2013 | Denon AVR 1312
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Denon avr 1312 green power flashing green 7 times
Sounds like a bad power transformer. Would need to go in for repairs.
Jan 09, 2013 | Denon AVR 1312
Denon 1312 makes clicking sound will not turn on
If the front display does not light up at all when the press the power button, it is usually either the main power fuse or the power transformer. If the fuse is blowing, that usually means a short in the amp section.
Dec 26, 2012 | Denon Avr-1312 Home Theater Av A/v...
My denon avr 1312 does not start. the power butten is red but not flashing. display off. no reaction whatsoever. any ideas?
unplugged the unit and do these reset
if these have already been done, and symptoms persist
the unit needs servicing.
Aug 20, 2012 | Denon Avr-1312 Home Theater Av A/v...
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
Denon AVR-1312 5.1-Ch A/V Home Theater w/ 3D Logo
116 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
