Question about Linksys Wireless-G Broadband Router
Laptop will not connect to my router and different router with a weaker signal is being detected
I have been my linksys router to connect to the internet for the last six months. Today my laptop would not connect and my laptop is showing "belkin g plus" as another way to connect I guess someone in the area has hooked up this router in any case I can no longer connect to my router. I just want to use my linksys router connection. My email is pizzacafe@tampabay.rr.com thanks Kevin
  • ikkenom May 11, 2010
    Remove the AC power from the router.
    Reconnect the AC power to the router, and wait for the router to restart itself.
    Now, can you connect with a network-cable between your computer and the router, and surf the Internet?
    Disconnect the network cable, and see if the wireless-adapter can "view available networks" to see your network.
  • Nathan Cain
    Nathan Cain May 11, 2010
    What have you tried to do to fix this? I will let you know some other things you can try.
    P.S. if you want to talk, call me at 1-800-320-9683 ext. 01043876
  • 611 Answers
Just update your router and installed the latest firmware in the router then you try it you got it
Posted on May 21, 2009
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 08, 2012 | Linksys Wireless-G WRT54G Router
My laptop cannot connect by wireless to linksysWRT54G
You can follow the steps from my tips in order for you to correct the problem that you have, check this link for the step by step procedure to fix the problem.
http://www.fixya.com/support/r3791502-resolve_intermittent_wireless_connection
May 14, 2010 | Linksys Wireless-G WRT54GS Router...
Lost wireless signal
Check the WLAN light on the Linksys Router if it's still on and make sure that the Wireless Adapter is ON on your HP computer and can detect other wireless networks, if WLAN is off try to do a power cycle and check again the lights... If lights are ok... connect your PC to the LAN port of the router and access the admin page, try changing channels and see if your wireless computer can detect it, if still not try to do a hard reset on the router
Mar 02, 2010 | Computers & Internet
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
Laptops connect to router but still cannot get on internet
It's just a wireless interference problem. All you need to do is change the wireless channel of your router. Login to the router's admin page and look for wireless channel under the WIRELESS tab. Change it to channel 11 and save the settings. That should solve your problem. You can play around with different channels and check which one is the best for your environment. Good Luck!
May 07, 2009 | Linksys Wireless-G WRT54G Router
Linksys router when cabled, doesn't work wireless to laptop
can it detect the wireless signal?
did you load the drivers for wireless card in laptop?
check the device manager for any ! or ? in it those need attentio
if you can detect the wireless network then you need to set the wepkey if its enabled. if its not and you have a signal then just click on connect in the wireless network manager
Jan 22, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
2200bg card - weaker signals
Try using a different channel as there may be interference from other appliances. You are probably on channel 11 in the routers settings, so experiment with a channel from 1 to 10, but don't forget to change the channel of your wireless card also.
Mar 07, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys Wireless-G Broadband Router Logo
213 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
