Hello i have a pc from acer model aspire X3900 with the motherboard acer FIH57 and i want to connect the front panel to a other box and i lost the manual from the motherboard is there any change to find the manual online or someone send me a photo of how to connect the front panel?
  • 13433 Answers
SOURCE: manual for the aCer aspire 5520 model# ICW50
Hey,
Here is the user guide for aspire 5520
You will need to open a new internet page, and copy this text fully into the addressbar to download the guide, starting with ftp:
ftp://ftp.work.acer-euro.com/notebook/aspire_5520/manual/Aspire_5220_5520_5520G_EN.zip
The zip file has the pdf format manual inside, if you can't open it let me know.
Posted on Nov 26, 2008
SOURCE: ASUS p5kc front panel connector
www.azmanual.com/manual/731/asus-p5kc-manual-e3155/
Above is a link to P5KC's manual.
Search (with ctrl+f) for 'front panel audio' and you'll find pictures how to connect front panel functions (like reset, audio etc).
After you have connected frontpanel audio connectors correctly and there is still no sound coming out of your audio device, you need to change front panel type from bios.
Reboot your pc to bios (press del on bootup to enter bios).
You will find 'Front panel type' item in bios. Change it from 'HD Audio' which is default, to AC'97 and save changes you made and exit from bios. After you do that your computer should reboot and audios work fine from front panel if you dont have anything muted.
Posted on Mar 13, 2009
SOURCE: Volume My Acer Aspire One AOA110-1588 PC Notebook
If ur question is dat u dont have volume to ur laptop..Install the Audio drivers provided by the Acer eRecovery.I hope it will slove ur problem...If not restore ur laptop to factory setting.
Posted on Apr 22, 2009
SOURCE: Acer veriton 7100 front panel audio pinouts
gfexcel  vga drive
Posted on Jun 26, 2009
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard (FP1 Pins)? Thanks!
Look onto motherboard there is marked as a name of pw btn--power button and plug in front pannel pwr cable pin here
Sep 23, 2014 | Acer Aspire 7720 Notebook
Acer Aspire M5100 desktop manual
Here is the Complete Manual for your Computer .
CLICK HERE.
Aug 17, 2012 | Acer Aspire One PC Notebook
Acer aspire 1201 f-panel wiring diagram
you'll need the motherboard make and model to find the wiring diagram...should be in big letters on the board
Jul 20, 2012 | Acer Computers & Internet
My acer aspire 5733Z-4851 donot read usb
That could be a problem with the USB connection on your motherboard. This is not a big issue, if you can you just open up your CPU and locate the USB connection on the motherboard. It is not clear to me whether it is the USB ports from the front panel or it is the USB ports that are on-board (usually found at the back). If it is the USB ports from the back, the one built - in on the board, then the BIOS has to be configured again to enable Plug and Play attributes. If the ports are from front then you need to follow the cable that connects the usb port to the mother board. Disconnect and reconnect. Or check whether it is actually connected to the right port on the motherboard. Usually it is written on the motherboard.
Jun 11, 2012 | Acer Aspire 5733z-4851
ACER FIH57 drivers
This a Gigabyte related problem, not Acer.
In any case:
http://www.acer.com.au/ac/en/AU/content/drivers
Jan 11, 2012 | Gigabyte Computers & Internet
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    How do I enable the wireless on my Acer Aspire one?
    Open control panel scroll down to Internet connections and click to display. Right click wireless wizard then click choose enable. After this you will be prompted with a box that will show you that the computer has detected wifi connection in the surrounding.
    Jun 22, 2009 | Acer Aspire One PC Notebook
    Lost wireless connection
    try to turn on the wireless bottom on your front-panel.
    if that not work. go the connections and check if wireless connection is deactivated.
    CS.
    May 19, 2008 | Acer Aspire 5630 Notebook
    Computers & Internet Logo
    81 people viewed this question
    David Payne
    David Payne
