Question about Autodesk Computers & Internet
Autocad 0xc000007b - Autodesk Computers & Internet
0xc000007b error xp
"The application was unable to start correctly 0xc000007b"
Read the answer given by Microsoft technical support at the URL below.
0xc000007b error
Apr 10, 2014 | Activision Video Game Consoles & Games
Assassin creed 4 0xc000007b error
Download Reginout to fix 0xc000007b error simply with some couple of clicks.
Jan 07, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Program error 0xc000007b
You didn't post what you were doing when you got the error? Take a look here: http://www.tomshardware.com/forum/63536-63-error-0xc000007b
Apr 19, 2013 | Computers & Internet
Autocad 2010 failed to run properly (0xc000007b). click on OK to terminate the application
You might have to uninstall the current version of autocad you have on your computer then restart your computer then run the jet clean utility. http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted. Then reinstall it
Hope this helps.
Jan 14, 2013 | Computers & Internet
0xc000007b
0xc000007b is usually caused by a corrupt registry entry. The best thing you can do, to prevent your PC from getting more error messages or further registry corruption, is to fix this problem immediately, by following the easy instructions below. The potential risk, resulting from not repairing this error, could include system crashes, blue screens, and hardware failure.
  1. Download the 0xc000007b Repair Tool
  2. "This is a free download - You'll see a new window pop-up for confirmation."
  3. Click "Save File" and follow the simple installation instructions.
  4. Scan your computer with the Regcure application.
  5. Click the "Fix Errors" button to repair 0xc000007b.
Feb 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
0xc000007b
Could be a virus called WORM_KLEZ.E
Do a virus scan.
If theres no visrus try using system restore back to when the error message wasnt there.
Make sure automatic updates are turned on.
Aug 20, 2009 | Microsoft Windows XP Professional With...
0xc000007b error
re install windows - your computer has crashed.
Apr 19, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
