Audio but no video
Ausio works fine but screen is black
ThaMp3Doctor
  • 8596 Answers
SOURCE: Videos appear as a blank black screen
need latest Quicktime ver
Posted on May 26, 2008
kram26
  • 544 Answers
SOURCE: Web cam is not working properly.
if you still have your cd driver for your cam you can try to reinstall it..
to change and fix your problems it is the best option we can do.
thanks,
Posted on Mar 20, 2009
Bennytechkid
  • 99 Answers
SOURCE: mine also appears if "backlight" went out.
By almost balck do mean you can kinda see an image but it is really dull??... well if so it means the backlight tubes are gone..in most small screens including laptops the backlights are micro flurensent tubes..the have a small inverter supply....usually located at the base of the screen...so take out prbably four screw located more than likely under rubber pads on the face of the screen and pull the outside panel off.....you should see the screen unit and a small PCB below it and it should have a mini Transformer with a conector comming off of it with a Pink wire and a white wire...this goes to the tubes! make sure using a muti-meter there is voltage at those pins...im not sure how much but if there is none it means inverter supply has died...you should be able to get a replacement...contact an electronics store or supplier .....if there is voltage then the tubes have gone(which is the most common fault!) again im sure where you can source them from in your country but try electronic stores or contact the tech department of the manufacturer of the unit they should have some in stock!
Posted on Aug 11, 2009
rcalorisian
  • 313 Answers
SOURCE: player works fine, no video on extra lcd screen,audio ok
It can, but unless you have a real good DVD player, it will cost more to fix. It doesn't show you model so I can only give you limited help.
If you paid over $100.00 and it is a HD or Blue -Ray, then you can take it to a repair shop. If not, it would be better to go shopping for what you will pay out to have it fixed.
I am sorry if that is not what you wanted to hear, but, thank you for the chance to help.
Randy
FixYa Support Team
Posted on Oct 14, 2009
Testimonial: "I figured as much. Thanks for the help. Looks like I'm off to the store. Great to have such a quick opinion."
  • 1684 Answers
SOURCE: screen is black, audio works fine
This usually indicates a failure in the backlight power supply. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ that explains what goes out and what will need to be replaced to complete the repair. You can also post a few pictures of the power boards to our forum section at: http://www.ccl-la.com/forum/index.php Our techs will then contact you about the parts that have failed. If you don't want to do the repair yourself we do offer a repair service, that information can be found here:http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Mar 13, 2010
Samsung tv audio but no video
Check the voltages on the connectors going out to the boards from the PS (power supply)
...let me know what you find
Oct 23, 2017 | Samsung Televison & Video
No sound. Lights up
Try this instead, when you look at the back of the receiver, try and jiggle each chord connected, just to see if one might be loose.
IF NOT -- try and make sure the settings on your tv is correct, most receiver boxes use and HDMI cable for video and ausio as a dual connection so if the HDMI settings in your internal settings are off, you might need to update the settings and then it should work
Jun 16, 2015 | Audio Players & Recorders
Sound
The audio head when you look from front side of VCR on your right side of video head. You must the adjust the head with a screw in the bottom of audio head.
Mar 12, 2010 | Philips Magnavox DVD/VCR Dual Player
My dvd player is a jvc oct. 1999 it is connected to the tv. through a modulator, all the wires hooked up right for sound. The t.v. sound works but when the dvd plays it does fine but no sound. the serial...
Are you by chance using a SVGA cable alone? I am not sure of your cable configuration, but the SVGA cable only sends video.. this sounds like your issue. Check your cables to the modulator box from the DVD to make sure the RCA jacks are from audio l/r out on the DVD to ausio in on the modulator.. hope that helps..
Stan Skaggs
Sep 28, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I turn on my ps3 and the screen is black
Have You Pluged In The Yellow Video Cord All The Way?
Aug 14, 2009 | Sony Playstation 3 (PS3) Console
Ford Car audio system locked out(shows err)
Well i dought that anyone here has the right set of codes you need laying around so I would take it to a delership and have them unlock it for you, the most it will cost will be around $40
Feb 06, 2009 | Car Audio & Video
Ps3 video and audio comes and goes
TRY playing game using standard line input cable and see if there is a difference
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
53FDX01B Picture went black
is the screen lit up?
If so the video module is bad.
replace the surface mount caps app. 8 to 10
or replace module
guy9
Aug 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
