Question about Maytag Atlantis MDE7657BY Electric Dryer
Burning smell but the belts are good - Maytag Atlantis MDE7657BY Electric Dryer
  • 51 Answers
Check the air discharge and element. Make sure all lint is removed.
Posted on Jan 06, 2014
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Bearing on brush is hard to turn and smells like it's burning
bearing hard to move will put strain on the belt and burn it. the bearing is easily removable pull it off, sometimes its just a good clean it will need, if will not come off tape it off. remove the muck build up and give the bearing a good soak in some wd40 or oil and wipe off and check for good movement then replace the belt. as it will snap more easy now it has been heated up.
Mar 15, 2014 | Eureka The Boss Upright Vacuum Cleaner
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Battery light on and a strong burnin rubber smell
SOUND LIKE ALTERNATOR SHAFT BEARING FAILING CAUSING ALTERNATOR PULLEY LOCK OR PUT DRAG ON DRIVE BELT CAUSING BURN RUBBER SMELL OR DRIVE BELT LOOSE CAUSES BELT SLIPPAGE MAKE BELT RUB AND BURN.WHEN YOU SMELL RUBBER BELT BURN SMELL WATCH OUT DRIVE IS GOING TO BREAK.
Aug 04, 2011 | 1983 Ford Fairmont
Washer wont spin, smells like burning rubber
The burning rubber smell is coming from the belt which goes around the drum and is driven by the motor. The belt has probably stretched and is now slipping. It will need to be replaced.
Jul 13, 2011 | Washing Machines
I noticed a smell coming from the mastercool and now the low speed and low cool does not work.
is it a burning rubber smell or a burning eletric smell. burning rubber smell will be a slipping belt. replace the belt and pullys. tighten belt. electic smell will be a bad thing. have tested by technition
Aug 12, 2010 | Mastercool 67680 Evaporative Cooler Air...
BURNING SMELL COMING FROM MY WASHING MACHINE
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Aug 05, 2009 | Washing Machines
Won't spin on spin cycle, smells of something burning.
sounds like the belt or the tub bearings are shot. It is likely that the motor is spinning and the tub is not, causing the belt to burn.
May 25, 2009 | Maytag Washing Machines
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Maytag Atlantis MDE7657BY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
