Admiral washer my washer wont do anything after the water comes in and makes this loud humming sound
  • rotova margarita
    rotova margarita Jan 02, 2014
    Hi Marissa , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Marissa
    Marissa Jan 02, 2014
    I have an admiral washer atw4475vq0 when you start the washer on the cold cycle and regular mode the water will begin coming in and fill up but it never goes past that point, when you try to turn the knob to a different cycle you get this loud humming sound...my husband emptied the water out and turned the washer over he says he did not see anything caught in the washer nor did he see the belt was bad or loose.We just bought this washer about 2 1/2 years ago from home depot
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
roelskii
  • 14 Answers
SOURCE: Washer comes on and it makes a humming noise
is the motor running?? maybe its stuck....
Posted on Jan 14, 2009
  • 132 Answers
SOURCE: top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
localwonder
  • 6784 Answers
SOURCE: Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Posted on Jul 13, 2009
hh0405
  • 77 Answers
SOURCE: Frigidaire Affinity washer: Straining water pump? Humming.
more than likely the pump is clogged if you pull the the washer out away from the wall and then lean it back to get under it there is a hole to access the under side you can reach through to the pump then disconnect the large hose that goes from the tub to pump reach down inside of this hose remove the cup that has debris in it and clear it out remove the debris and reassemble the washer
Posted on Apr 03, 2010
Water won't come in. Hums, fill light flashes once but no water
Sounds like a bad inlet valve--the part the hoses connect to. You may want to check that the house valve at the washer did not somehow get turned off also. The hum is the valve trying to open.
May 20, 2015 | Admiral Washing Machines
Afmial washer makes a loud squeeling sound all the time
The squeal is most likely the belt. check that it is in place and not coming loose or stretching out. The other culprits could be the water pump, the bearing to the drum, or the motor, in that order of likelihood.
Nov 08, 2012 | Admiral 3.4 cu. ft. Top Load Washer in...
Washer fills with water, but then wont run
Check belt underneath has not broke or come off.
May 06, 2010 | GE Washing Machines
I over loaded my washer and it makes a shreeking sound?
If the sound is a loud buzz, the inlet valve is electrically ok but mechanically faulty. Replace the inlet valve.
Oct 23, 2009 | Admiral AW22 Top Load Washer
Our washer wont spin fast and shuts off saying ND code. what does that mean
ND means that it is Not Draining. Does it make the same water-pump sounds that it used to make at that point in the cycle? In my machine, it sounds like a low-pitched loud hum when it's working.
It might be that your water pump needs replacing. If there is any strange sound (such as grinding) then there might be a coin or something stuck in the pump.
Sep 29, 2009 | Samsung WF337AA Front Load Washer
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
Loud Clicking rattle during spin
you may have something stuck in the pump
pull hoses off pump and see if there is anything stuck in it
Jun 13, 2009 | Admiral AW22 Top Load Washer
Washer will not spin it makes a humming sound
This could be a broken drive belt ($$$) but it may also be the door-closed sensor switch. If this switch get's sticky or bent it will not sense when the door is closed and the machine will not spin. It's usually a little slot somewhere around the edge of the door opening and a little finger on the door fits into the slot when the door is closed. I'd sticking a pencil or similar into that slot when the machine should be spinning and see if it helps.
I've fixed this with a little WD-40 sprayed into that slot to limber up the switch.
Please be careful and do not over-ride the function of this switch.
Apr 26, 2009 | Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
