Question about RXE160 Equivalent NTE16013-ECG POLYMERIC FUSE
Equivalent numbers definition of equivalent fractions
What fraction is equivalent to 2/3
4/6
6/9
8/12
10/15
etc. Just keep multiplying by the same number on both sides.
Apr 17, 2017 | Office Equipment & Supplies
What is the equivalent fraction to 0/2?
If we have no pizza, and divided it between you and me, how much do we get? ZERO.
However, you want equivalent fractions to 0/2. To get an equivalent fraction, you multiply the numerator (the number on the top) and the denominator (the number on the bottom) by the same number.
So we can multiply the top and bottom by 2.
0 x 2 = 0
2 x 2 = 4
So an equivalent fraction would be 0/4.
Good luck.
Paul
Mar 18, 2015 | Office Equipment & Supplies
What are 4 different fractions that are equal to 1 1/2
Hi Anonymous,
You can make equivalent fractions by multiplying or dividing both top and bottom by the same amount, but only multiply or divide, never add or subtract, to get an equivalent fraction.
I've only shown the fraction part of your question as 1 is a whole number.
1/2 = 2/4, or 4/8, or 8/16 or 16/32 or 32/64 & so on.
Going the other way, dividing 2/4 by 2 will give 1/2.
But, only divide when the top and bottom would still be whole numbers, for instance you wouldn't use divide for odd number fractions, for example 1/3 or 3/5 etc.
Trust this helps, best regards Alan
Feb 11, 2015 | Office Equipment & Supplies
Equivalent fractions
Any fraction where you multiply 4/9 top and bottom by the same number eg 8/18
Nov 04, 2013 | The Learning Company Achieve! Math &...
Two repeating decimals equivalent to a fraction with the denominator 10
A number with a periodic decimal representation cannot be equivalent to a fraction with denominator 10 (or a multiple of 10) except if the repeating decimals are zeros.
0.454545...=45/99=5/11
Sep 04, 2013 | Super Tutor Pre Algebra (ESDPALG)
How can 36/63 be reduced
It is simple. 36=4x9 and 63=7x9. The number 9 is a common factor in both numbers. You can simplify the fraction by dividing both the numerator and the denominator by 9.
36/63=(4x9)/(7x9). You can rewrite the fraction as (4/7)*(9/9)=4/7 because 9/9=1.
The reduced fraction equivalent to 36/63 is 4/7. Since 7 and 4 have no common divisor you cannot reduce the fraction further.
Jan 05, 2012 | Office Equipment & Supplies
How to convert fractions into equivalent fractions
find the least common denominator between the original fraction into the new fraction.
example, 1/2 to 2/4 to 4/8 to 8/16.
May 19, 2010 | Cycling
Write a ratio equivalent to 7:17
Read the definition of equivalent ratios. Choose the numbers a and b such that a/b=7/17. (Here is a HINT: The operation to perform to obtain a from 7 and b from 17 is the inverse operation that you use to reduce a fraction to its simplest form.)
Once you dtermine how you are going to construct a and b, the calculator can then help you express each one as a single number.
Sorry I cannot be more specific: You have to make a little effort to understand what you are supposed to be doing.
Sep 22, 2009 | Office Equipment & Supplies
RXE160 Equivalent NTE16013-ECG POLYMERIC FUSE Logo
125 people viewed this question
Top Nte Vehicle Parts & Accessories Experts
Eddie Dalton
Eddie Dalton
k24674
jasbo
jasbo
Are you a Nte Vehicle Part and Accessory Expert? Answer questions, earn points and help others
