Question about Ertl 580 Super M Series II Tractor
Need to clean Diesel fuel tank on my Case 580 B Backhoe Can't remove tank
The fuel tank needs to be cleaned, but I can not remove the tank because it has a cross bar over the top and don't have clearance to go forward or backwards
SOURCE: Case 580C model 33 backhoe - transmission problems
Pregunta , tienes, el manual de la case 580 ck, donde se muestra el circuito hidrailico de la transmision, si es asi, embiame una foto del circuito o el manual y te puedo apoyar.
Posted on Jun 01, 2009
rynanlimpiad
  • 36 Answers
SOURCE: 580b case backhoe trackter will go forward somtime
check the connection of your control circuit
Posted on Apr 06, 2010
SOURCE: case 580 tractor no forward
backhoe will not move forward
Posted on Aug 14, 2010
bbl242003
  • 1637 Answers
SOURCE: case 580 super l stops as i drive it forward
What is the last thing that happened before you noticed there was a problem?
Posted on Jan 13, 2011
richroth
  • 9472 Answers
SOURCE: case 580 super e.
You are having the typical shuttle failure. There is a bellville type spring that returns the clutches when pressure is taken from the clutch pack. That spring will fail with time, it is nothing you did.
Posted on Aug 11, 2011
Still looking for what case backhoe has for ohm range on fuel sending unit. case 580 sl series 2 empty to full
Click on the link, I can only talk to you in automotive terms. I know nothing about a backhoe. The sending unit has to have voltage, correct? Get a resistor for empty and one for full, If the gage acts proper to the resistors, the problem is the sending unit.
If that isn't the answer you wanted, sorry, that's all I got.
http://www.tanksinc.com/index.cfm/page/ptype=results/category_id=159/mode=cat/cat159.htm
May 01, 2017 | Cars & Trucks
How to time fuel pump on a 580 backhoe with cummins motor
need to know the pump make and engine size as there are various pumps used on cummins engines.
Feb 12, 2015 | Cars & Trucks
I accidently put diesel in my John Deere riding lawn mower. How do I safely drain the tank. Or do I need to take the tank completely off? If so I need directions.
If you did not try to start it, you will need to siphon, pump or **** out the fuel tank. The last J.D. that I emptied the tank in I used a turkey baster to draw out the bad fuel. I guess you use what you got. Hopefully your fuel is pumped to the engine and the fuel line goes into the tank from the top. If so all you have to do is empty and replace with gas. If the fuel line drains the tank from the bottom and/or you tried to start it with diesel in it you will need to (after emptying the tank) remove the fuel line from the carb. and direct it to a container, remove the bowl nut of the carb. to drain carb. be ready to clean up a little spilt fuel catch if you can or have rags under and ready. Turn the ignition key for engine to turn over to operate the fuel pump and clear the line. Put a little gas in tank and flush fuel line by using fuel pump to clear. Change fuel filter and put everything back together. Remove and clean/replace spark plug. Test it. Inspect spark plug again if necessary.
Jul 07, 2011 | Garden
My diesel burner on my pressure washer smokes real bad. Could I have a leak, if so where would that leak be? It is a alkota
HI, here is a few pointers that may help you ,
  1. if the smoke is white , that usually indicates water in the diesel, empty fuel tank and replace/clean the fuel filter
  2. if the smoke is black that indicates excess diesel or unburnt fuel , normal fuel pump pressure is around 8 to 9 bar (you will need a gauge to check this ), another cause is often failure of the fuel nozzle to correctly atomise the fuel (remove nozzle and clean (a small sintered fuel filter inside this )
  3. the burner electrodes should have a blue angry looking spark across them ,when checked (BE VERY CAREFULL WHILST DOING THIS as in effect you have a flame thrower ), usual gapping distances are around 6 mm
  4. the electrodes should be sharp pointed and not rounded or pitted
  5. a final cause is commonly a leaking fuel solenoid which can cause fuel to drip into the burner/heating coil assembly ( replace the solenoid
as you can see this can often be a complex and dirty job to repair and it might be better to contact a local service agent in your area .
Hope this helps
Jan 28, 2010 | Briggs & Stratton Pressure Washer...
How to drain ford fusion fuel tank
The "MOST EFFECTIVE
" way is to REMOVE The FUEL TANK and DRAIN it By Tipping it over to Pour From FUEL INLET HOSE. Im Sure you Dont want to Here this as it Requires Much WORK . , BUT It IS The MOST EFFECTIVE Way to EMPTY The TANK.
Oct 31, 2009 | 2004 Ford Fusion
Apr 29, 2009 | Ertl 580 Super M Series II Tractor
Ertl 580 Super M Series II Tractor Logo
83 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
