Question about Westinghouse VR-4030 40 in. LCD HDTV
Surround sound problem
Surround sound cannot be setup on tv. sound menu shows analog sound as N/A
    Top Expert:
  • Westinghouse Master
  • 14,161 Answers
Posted on Jun 27, 2016
2 Suggested Answers
  • 8457 Answers
SOURCE: Our LVM-37w1 Westinghouse TV has
Go into tv menu.Goto AUDIO SETTING,go down to reset.This will,reset it back to tv factory setting.The sound now,it working trought ur tv speaker again now.
Posted on Sep 09, 2010
No sound
Check the tv menu to ensure that speakers are on. And disconnect any cables that went to the surround sound.
Nov 30, 2013 | Sylvania LC420SS8 LCD TV
I have a lg 60 inch i tryin to get the sound to come out of the surround system
connect the audio out of the tv to any input of your surround reciever. ou can use optical out from tv or analog out. then select that input on the reciever. you can go into tv menue and turn off the speakers in the tv. Recommended.
Aug 30, 2011 | LG 42LG50 42 in. LCD HDTV
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
TO GET SURROUND SOUND I NEED RCA CABLES WERE DO THEY GO ON MY TV
You won't get surround FROM your TV. It's just a lightshow device with bare minimum speakers and audio chops.
Get the TV-related audio from the same source IT IS WATCHING - Cable/SAT/DVD/BluRay/Game. Digitally, if possible. Otherwise you'll just get stereo analog sound.
Jun 10, 2010 | Audio Players & Recorders
Lost my sound in my surround speakers
Check your speaker setup onscreen ( monitor) viewed configuration, be sure you are enabling SURROUND SPEAKERS, or REAR SURROUND if you are running 7.1, then check the AUTO input to be sure you are receiving a MULTI-CHANNEL SIGNAL within the DIGITAL/ANALOG source. Cycle through the DSP Analog modes ie. Pro-Logic, Rock Concert etc. and check your DIGITAL signal indicator for a 5.1 DD or DTS input, if you hit a unitentional button then you will just need to reset it back to prior operation before loseing the surround speakers.
Feb 20, 2009 | Denon Audio Players & Recorders
Home Theatre Setup
Need specifics. Model numbers.
What works properly?
RCA cables where? Details.
I need more to information be helpful.
Jan 17, 2009 | Yamaha HTR-5930 Receiver
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
May 23, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Westinghouse VR-4030 40 in. LCD HDTV Logo
32 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
