Question about Polaris Interactive Toy Concept Polaris Rush Snowmobile
Polaris clutch - Polaris Interactive Toy Concept Polaris Rush Snowmobile
    Top Expert:
  • Polaris Master
  • 2,044 Answers
Need more information
Primary or Secondary?
What is wrong?
need more information
Posted on Mar 01, 2014
What kind of oil can a use for a 2005 polaris predator
Semi-synthetic 0w40 oil for the 500,600,700 sportsman quads, check what clutch your ATV has, "cvt" (continuosly variable transmission) clutches, or 'wet clutch'. 10w-40 or the 0w-40 that has the additves for "wet clutch" aplications
Jun 09, 2013 | Polaris 2005 Predator 500 Troy Lee Edition
How to remove a clutch from a 1994 polaris pvt
Jerry,
This is the forum for the kids toy, you might have better luck if you post in the atv forum
Jun 25, 2012 | Polaris Trail Boss ATV
Polaris 330 mag, barely moves in reverse? possible ****** problems??
If the belt has been changed, the button ramps in the secondary clutch should have been checked. The secondary clutch has 3 ramps that tend to wear, and this will wear the clutch out if not replaced right away. To remove the secondary clutch (rear clutch) remove the clutch cover and belt. Remove the bolt from secondary clutch and pull clutch off. The clutch is on a splined shaft so a puller will not be necessary. To check the ramps inside the clutch, rotate the outer sheave clockwise while holding inner sheave stationary. You should be able to see the ramps, if not they have worn completely gone and the clutch will have to be disassembled. Check this and let me know what you find. I will be happy to assist if you need to disassemble the clutch, Daniel.
Jan 12, 2012 | Polaris ATV
2011 polaris 500 sportsman ho ...going down hill it free wheels is this normal ?
Yes this is normal for the 2011 Sportsman 500. The 500 does not have a one way bearing in the clutch acting like an engine brake as do the previous years. Polaris removed this option for the 500 sportsman in 2009. If you were to own a 550 it would not free wheel down a hill.
Aug 14, 2011 | Polaris ATV
Have 2001 polaris sportsman 4x4 and put new belt on and go only 20 mph than engine reves up but dont go faster please help
sounds like your clutch is stuck and wont open up to let belt drop in between pulleys. check both the drive clutch and the driven clutch fo no binding or for smooth operation. that would keep the wheeler in a low gear position
Jan 05, 2011 | Polaris ATV
How to remove a starter on a polaris scrambler 500 1999.
I have found it is easiest to remove the clutch and back clutch cover, along with the recoil starter.
Jun 28, 2010 | Polaris Scrambler Men's Mountain Bike
How to replace a polaris 325 starter
you must remove the clutches on the left side of the machine. this requires a special puller to remove the front clutch. everything else is straight forward. pullers are available at your dealer or on the web
Feb 15, 2010 | Polaris ATV
How do i remove the drive clutch on an indy sport touring 440 1996
you need a clutch puller, Take out the center bolt and the clutch puller will thread into the same hole,as you tighten it up it pulls the clutch off; Good luck
Jan 26, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 96 polaris xplorer 3004x4 how do i get hillard clutch off
If you are removing the driven clutch, the rear most one, it simply slides off. if you are removing the drive clutch, the one on the motor, you need a 3/4" fine thread bolt. And something to use as a spacer, I used a socket that fit down the hole. just put the socket in first then tighten the bolt against it until the clutch pops off. Be careful you don't use anything that may bend in there and cause more headaches.
Jul 16, 2009 | Polaris ATV
1990 polaris trailboss , trans ,or clutch slips in water
Check for wore clutch belt and also check to see if your getting water in the clutch housing. If your getting water in the housing, your clutches could be corroded as well. There should be no water getting in that shroud.
May 18, 2009 | Polaris ATV
Polaris Interactive Toy Concept Polaris Rush Snowmobile Logo
87 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
