Question about Fisher and Paykel GWL11 Top Load Washer
Does not rinse and drain water - Fisher and Paykel GWL11 Top Load Washer
  • Fisher and P... Expert
  • 554 Answers
You should be getting a fault code on the wash progress lights.
If water is still in bowl try this.
37. (00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3
minutes. There are three likely reasons for this fault. One is that the drain hose or the
pressure switch hose has been squashed or kinked and the pump out rate has been
dramatically reduced. The second possibility is that the pump is partially or fully blocked.
The third is that the pump is not operating due to Motor Control Module, wiring or pump
failure. This fault could also appear if the machine is pumping to an unusually high head of
drain hose or into an extended length of drain hose. The fourth possibility is a diverter
valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation
mode, giving the module the appearance the pump is not lowering the water level.
Primary Source: Pump System.
Action: 1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 1-metre extension hose of the same diameter
fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain
hose is not blocked.
5) If the bowl contains water, then service the pump from the top of
the machine by removing the top deck and inner bowl. Bail out the
water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action: 1) Check the pump harness is connected correctly to the pump.
2) Check continuity of the pump harness.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
pump is rotating. If it is not operating, and Primary and Secondary
checks have been performed, then replace the Motor Control Module.
Posted on Jan 02, 2014
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
It will not drain the water on the rinse cycle
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 24, 2010 | Maytag Washing Machines
Drain washer pump for winter
Turn off the water at the cold and hot taps. Disconnect the hoses from the taps and the washer and drain them. Lay the drain hose flat on the floor to drain it to a container. With the hoses disconnected and the drain hose flat, start the fill cycle (set to WARM) briefly (15 seconds) to open the inlet solenoid valves and allow water to drain from them. Start the rinse cycle to pump any residual water out of the tub and drain (15 seconds).
OR
Turn off water and disconnect inlet hoses as described above. Pour 1 gallon of RV anti-freeze (for potable water systems) into the tub. Start the rinse cycle just enough to start the drain so antifreeze goes through pump and into drain hose. Before using the washer again, run a small rinse through to flush out the anti-freeze.
Nov 11, 2009 | Office Equipment & Supplies
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Fisher and Paykel GWL11 Top Load Washer Logo
27 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
