Question about Akai LCT3285TA 32 in. LCD Television
Tv want show
I hook the cable up no picture will show
  • littlebite Oct 19, 2007
    tv want work w/ cable
    Problem Solver:
  • 5 Answers
Look at the back of your TV.  Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs.  Wait one second between pushes.  You want to stop just before the source that displays "AV" on TV screen.  It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4.  If you use no cable box, try changing channels on TV to find an active one.  If no luck, make sure your cable service is active (subscription active).  Cable companies disconnect it between residents of an apartment/house.
Posted on Oct 31, 2007
Have blank screen with sound. Flashlight test shows writing etc. Says cable not hooked up when it is. When HDMI cable is hooked up it shows up.
I hope I can help with this. It could be either the colored cables are not positioned correctly (they should all be on the same row) or it is on the incorrect TV Input. This can happen when we have other devices connected to the TV such as CAble box, gaming console (xbox, ps4,wii), dvd player, etc. The fact that you said the HDMI cable works fine and shows picture, it tells me it has to do with those colored cables.
Jul 28, 2016 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Windows 7 driver for orion SLED2468W
Settings usually with a good USB cable, the settings on your TV when doing input go to USB where pictures and cable will show and connect from your computer to the back of TV and if doesn't work call TV company they always know the hook to this.
Aug 13, 2015 | Orion 24" Class LED-LCD 720p 60Hz HDTV,...
Tv doesn't connect though coaxial hook up
Most of these TVs show a blank screen unless they are receiving a sinal?
Jan 28, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound) - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector.
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
Mar 05, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
Our dlp tv shows great color when watching tv but when we watch a dvd the red is brown and the pink is tan? HELP
if you already check your cables.. and it's still the same.. the problem is probably the VIDEO BOARD
here is a picture of what is a video board..
Nov 28, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
Mar 15, 2009 | Samsung Televison & Video
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Toshiba CF36G40 36" TV (picture snowy)
you have a bad tuner you can replace it or use vcr if you still have one around. hook it up with av cable like your ps2 and hook your cable to it and use it to change channels. If you want to replace the tuner it will require soldering and you will have to order it somewhere. i would try The tuner is the metal can the cable goes into inside the tv.
May 12, 2007 | Toshiba CF36G40 36" TV
Akai LCT3285TA 32 in. LCD Television Logo
153 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
