Question about Refrigerators
Freezing cooked meats
After defrosting and cooking can I freeze cooked meats again
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
daddy1264
  • 76 Answers
SOURCE: Water pooling and freezing inside bottom freezer.
make sure you have cleared the drain all the way to the drip pan, and the fridge should be tilted slightly to the rear for good drainage........make sure there is a clear path for the water to make it to the drain hole
Posted on Jan 03, 2009
tborn6
  • 700 Answers
SOURCE: Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Posted on Jan 08, 2009
SOURCE: fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Posted on Mar 18, 2009
aasc
  • 1606 Answers
SOURCE: the lights are on but it is not cooling or freezing
The overload/relay is shorted . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . Pt # 8201786 . Remove the back refrig panel to access the compressor . This part is easily replaceable . Instruction come with the part(s) . A little plastic "clip" needs to be released , when removing the plug from the part , by using a small screwdriver .
Posted on Sep 03, 2009
Food does not seem to be cooking properly. Did a pork roast and it came out dry and tough. Make tortelli soup and the celery and carrots were still hard.
you might need to freeze your meats if you have then you need to probably go with a different temperature on your oven by setting it to 350 degrees instead of 450 that could probably be why the meat is overcooking always baste your meat in juices from the meat use a turkey baster that can help or add more water to your meat and vegetables that takes more time for the meat to cook but the product will come out more juicer.
Apr 28, 2015 | Kitchen Appliances - Others
Can i defrost a piece of beef cook it slice it then refreeze it
Yes you can. If it is roast beef you might want to freeze it in beef gravy. Make sure it is sealed real good and use freezer plastic bags or if you have a food sealing device to vaccumm seal it. Deep Freeze meats cooked or uncooked last longer in a Deep Freezer as well!
Oct 13, 2014 | Refrigerators
Can I cook filet of beef then freeze for a meal a few weeks later
They can be frozen after cooking but will be better frozen until wanted.
Aug 23, 2017 | Refrigerators
How long can i freeze leftover ham
The answer is that it depends. I don't recommend freezing ham radios. Your owner's manual probably has specified a safe range of operation. Freezing your radio will more than likely cause permanent damage.
If you are talking about the food ham, you are in the wrong place. You can store ham frozen for as long as you want, provided you don't mind freezer burn. Generally three months is about the longest you can freeze cooked meat and maintain the quality.
Dec 30, 2013 | Radio Communications
Can i refreeze steak that has not been cooked
No definitely not once it has been defrosted thats it the best way is to cook it rare, then freeze it nice and hot all the way through when u want it cook again to the way u want it
Nov 07, 2013 | Computers & Internet
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Refreezing
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
Frezeer was unpluged by accident. All mear thawed out. Is it ok to refrzeethe meat and eat it later.
Is it safe to refreeze food that has thawed completely?
although there may be a loss of quality due to the moisture lost through defrosting. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. And if previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion.
If you purchase previously frozen meat, poultry or fish at a retail store, you can refreeze if it has been handled properly.
(Source: Freezing and Food Safety)
Charlie
Feb 10, 2011 | Refrigerators
I've defrosted chicken to make a chicken casserole but is it ok to freeze the casserole now once cooked for my baby in little food pots?
Yes, but ensure the casserole is thorughly cooked then cool and freeze straight away. This ensures ay bacteria do not get chance to breed. I have assumed you are liquidising before potting
Jan 21, 2011 | Home
What should fridge temp be for cakes and cooked meats?
the ideal temp in a fridge is +5C,no colder,or your veg will spoil.
Nov 02, 2010 | Refrigerators
Once a cooked meat dish is defrosted and reheated can it be refrozen?
It's not recommended. Once it has been defrosted and reheated bacteria start to reproduce on it. Freezing it will not kill the bacteria just stop or near stop their reproduction. However once it's defrosted again they begin to reproduce again so there's a much greater chance of food poisoning.
Aug 28, 2010 | GPS
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
