Question about Miele DA 249-4 Kitchen Hood
Miele da249 motor stopped running, light comes on, relay on cpu clicks. How to test if it is the motor or the cpu?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
They do not use a CPU. I would check things like is the fan free to spin? Check the capacitor with a meter. Check for power coming out of the power board. Most likely the power board faulty. The motors rarely fail. Also check connecting plug between the push button board and the power board. Just drop the flue cover off and make sure it is plugged in correctly.
Posted on May 06, 2017
Miele da249-1 motor not running, light comes on
Which light comes on? Indicator light or work lights?
Jan 02, 2014 | Miele DA 249-4 Kitchen Hood
The switches that control the fan (on ,off and speed) on my Miele DA249 ventilation system have been pushed in and do not work. The light switch is ok. Can you give me a part number for the fan controls...
Draw or photo the button order.Remove flue canopy. Unplug the control cable. You require the bracket kit from Miele. unclip the circuit board from the broken retainer. Do not lose the buttons. Clean the inside of the cover beyond throughly with metho and then sand paper. Assemble the button assembly and then with contact glue, fit in place. Use the foil tape to reinforce the bracket along each side.
Dec 19, 2010 | Miele DA 249-4 Kitchen Hood
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
The plastic clip that secures the buttons is broken
Hello.
You can order parts directly: Miele 800-843-7231
May 22, 2009 | Miele DA249 Kitchen Hood
Clothes not drying - fan ok, heat ok
I just had a Miele tech fix this. There are several causes for this. One cause is a motor fault with the fan motor or a bad belt. Second issue is a blocked up condenser. Finally the issue is electronic and the electronic panel needs to be replaced. The electronic panel consists of small relays that can burn out.
My issue was the electronic panel.
To test a blocked up condenser, is to take the top panel off, and spin the fan motor (by hand). If you feel resistance, you have a clogged condenser which must be replaced (Always run 'Remove Fluff' cycle so this never happens after every dryer use).
To test the fan, take the connector off and 'carefully' connect to 220v to the fan motor (checking polarity). Only do this, after you reset the switch (found in the rectangle box in the middle of the Miele metalwork on top) and made sure the fan does not work automatically when a drying cycle is selected.
The most expensive repair is the eectronic module which costs £175 plus £99 Miele callout.
Apr 22, 2008 | Miele WT945 Front Load Washer / Dryer
Keeps stopping
this relay is a starting device that works by supplying current to the motor's starting coil. Once motor has gained sufficient speed (the threshold speed}, this current naturally reduces to click the relay off and allowing only the "running" motor coil to take over. Now if the motor suddenly slows down, below the threshold speed, the start switch locking relay also drops out and you must press the switch again. So why may the speed begin to reduce? Possibly the drum bearings need lube or adjustment or the motor is just getting worn down or your power source is lower voltage than required (also look at wire size leading to wall outlet). Try to find one of these as your problem first. Just curious, do you have the same problem with no clothes in dryer? If not, then focus on ..if you do, then focus on [drum bearings need lube or adjustment or the motor is just getting worn down]. If you do, then focus on [our power source is lower voltage than required (also look at wire size leading to wall outlet).]
Dec 05, 2007 | Dryers
Keeps stopping
sounds like your mains filter which is situated next to your motor most dryer mains filters are the same easy to replace just undo back of dryer and you will see it at the bottom left hand of your dryer 1 14ml nut to undo to change it m8
Apr 01, 2007 | Miele T250C Electric Dryer
Miele DA 249-4 Kitchen Hood Logo
103 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Steve
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
