Question about AT&T ATT EL52500 DECT 6.0 5-Handset Cordless Phone With Digital Answering System, Silver/Black
Model EL52500 flashing In Use & handset no power at base
How can i deregister a headset from my vtech phone model#ls6475-3. Also, is there a limited to how many headsets you can register to the base.
You can deregister all of the handsets and then register each one again for the LS6475-3. Make sure that all of the handsets are out of the base and all chargers and that the phone and all handsets are in standby. Then press and hold Find Handset on the base. When the In Use light begins to blink, release the Find Handset button. During the seven seconds that the In Use light is blinking, press and release the Find Handset button. Wait for the deregistration process to complete (about 10 seconds).
If the process fails, you may need to reset the base. You can do this by unplugging the AC power cord to the base or by picking up a registered handset and pressing Talk/Flash. Then you can try again. These directions are on page 5 (page 8 of the PDF) of the manual for the LS6405 handset. The direct link to this manual is https://cdn-media.vtechphones.com/media/p/document2/products/%7BD6DAD9B0-4C1A-4882-93D9-04124A59B629%7D/LS6405_CIB_V5_20160805.pdf . Then check that all of the handsets are in standby and not on any charger before attempting to deregister the handsets again.
You can register 12 handsets to the LS6475 base, according to page 31 of that manual for the main unit: https://cdn-media.vtechphones.com/media/p/document2/products/%7BA37C95FC-053D-4D34-B60A-EA5ED42B056C%7D/LS6475-3_UM_4_925.pdf . If you use the cordless headsets, you can register 10 handsets and 2 headsets.
These manuals can be found through the product page: https://www.vtechphones.com/pd/1603/LS6475-3-2-Handset-Answering-System-with-Cordless-Headset . The base manual is in the section under the Support & Manuals tab. The handset manual can be found from the Accessories tab. Then click on the Support & Manuals tab after clicking the link for the Handset.
I hope this helps.
May 21, 2017 | Vtech Lands Phones
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Microphone on handset does work on outgoing calls
Check to see if you have pushed the "MUTE" button... it turns
off the microphone, another press of "mute" turns the mic back
on, etc.
Oct 17, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
the base cradle, etc.
The manual is available from: www.manualslib.com
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Nov 12, 2010 | Uniden Lands Phones
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
AT&amp;T ATT EL52500 DECT 6.0 5-Handset Cordless Phone With Digital Answering System, Silver/Black Logo
172 people viewed this question
Top AT&T Lands Phones Experts
Computer Repairing
Computer Repairing
Art Cacella
BenjamineDupont
BenjamineDupont
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
