Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Won't start, good battery
98 electraglide with the EVO...rode it one day, the next it wouldn't start. I can hear the solenoid click, but it won't turn at all. Battery seems fine. Any suggestions?
  • fluid_power May 29, 2009
    Thanx Redoil, the battery voltage was not sufficient. I changed the battery, put in a gel cell, and it fired right up. You are correct sir, you need 13.5 volts to start it. Thanks
    Mike
  • 355 Answers
WELL I WOULD CHECK BATTERY VOLTAGE IT NEEDS TO BE 13.5 THAT'S A GOOD BATTERY THEN I WOULD CHECK ALL GROUND FROM BATTERY SO YOU SAY IT CLICK DO YOU HERE THE STARTER MOTOR SPIN NEED MORE INFO TO HELP YOU THERE A WAY TO JUMP STARTER TO SEE IF IT SPINS BUT BE FOR WE GO THERE LET ME NOW THAT BATTERY VOLTAGE IS OK AND ALL CABLES ARE TIGHT.GOOD LUCK REDOIL
Posted on May 26, 2009
2004 yamaha yz250f ran all weekend then the next day after riding it, it wouldn't start
Hi, Alex and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Bike won start just backfires occasionally
Dirt Rider Magazine
YAMAHA YZ250F Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 24, 2013 | 2004 Yamaha YZ 250 F
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
May 30, 2012 | 2005 Nissan Altima
2005 electraglide won't start
Hi Anonymous, first when checking anything in the starter circuit you must make sure the battery connections are clean and tight especially the negative cable at both ends and has a 12.5 volt or better charge. It must not fall below 9 volts during the cranking procedure with a volt meter hooked up. If it does fall below 9 volts do a proper load test on the battery and replace if necessary. Second replace the starter relay cheap $6 and make sure it's well grounded and getting 11.5 volts or better to activate. Third remove the back cover of the starter solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. If it still chatters replace the solenoid. Good luck and have nice day.
Apr 08, 2012 | Harley Davidson FLHTCUI Electra Glide...
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
Sep 05, 2011 | 1998 Ford F150 Regular Cab
Atv wont start when electric start button is pushed
Iguess she hosed the machine down ,water may have tracked and drained the battery ,and what you are hearing is the solenoid clicking....try another battery or jumper leads off the car you may be surprised .WHAT EVER YOU DO DONT,I SAID DONT.,RUN THE ENGINE WITH OUT THE BATTERY HOOKED OR YOU WILL BURN THE RECTIFIER OUT!!! AND IT WILL BE UNABLE TO CHARGE THE BATTERY, if the new battery doesn`t do the trick , you are going to haveto follow the clicking by ear until you find where the clicks are coming from let me know PLEASE I also can learn from your experience
Aug 28, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Starter issues
try tapping on the starter motor/solenoid, it sounds like the solenoind is engaging(the clunk you hear) but the starter is not turning if the wire is getting hot it could be the starter is frozen up.
Jun 19, 2009 | 2004 Harley Davidson FXSTS - FXSTSI...
Lands Phones Logo
286 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
