Question about American Standard 4175.200.002 Colony Single Control Kitchen Faucet, Polish
Leak in the faucet handle
My american standard single control faucet leaks from where the handle meets the capthat covers the cartridge. How do I disassemble the handle to see whatis wrong and to replace parts if possible? What kind of screws do Ineed? and where to look? Thanks.
    President:
  • 2,559 Answers
Here is a link to the manual,Page 2 and 3 has the info you need.
Please take time to rate this a fixya
Posted on May 20, 2009
    Problem Solver:
  • 6 Answers
You'll need an allen or hexkey wrench of the apropriate sixe to remove the handle from the faucet. There should be a rubber plug with the traditional red and blue colors for hot and cold. Carefully pry the plug out. There should be a hex nut in behind the plug.Remove the hex nut and the handle should come off by pulling straight upward.After that the dome shaped nut that sits below the handle should turn off counter clockwise. Beneath this is where the seals, springs, and washers are located. Good luck
    Scholar:
  • 93 Answers
Most of the time you remove the cap covering the bolt and 90% of the time a allen wrench or hex bolt you need to tighten. If tightening it does not stop the leak you will need to replace the gasket.
Joe
How to fix leaky American Standard single faucet kitchen sink
The A-S single lever kitch faucet is terrible. If it is the one I think it is, then it has three screws that mount the cartridge down into the faucet body.If these are not torqued perfectly evenly, the faucet leaks. I suggest getting a Moen to replace it.
Apr 18, 2017 | American Standard Plumbing
I have an american standard kitchen faucet, when the handle is half open I get a leak, at home depot where I bought it two years ago, they told me I need to take it apart to see which kit will repair...
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge.
Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
Oct 08, 2010 | American Standard Kitchen Faucet 6310 020...
I have an american standard bathroom faucet. Single handle. It is leaking where the faucet meets the sink. I do not see any screws to take off the handle. How do I fix it?
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
Jul 16, 2010 | American Standard - Lavatory Faucet -...
How to replace sprout seal kit?
After you remove the handle, the chrome cap should either snap or spin off.It also may come out with the cartridge... There are 3 screws that hold the cartidge in the faucet...take them out and you should be able carefully work the faucet are off of the core of the faucet. Put a little cooking oil on the o-rings after you install the new ones... just to allow the faucet arm to slide on without damage... Hope this gets you dripless!! Let me know if you have a question. K
Jun 05, 2009 | American Standard 4175.200.002 Colony...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Mine leaks handle and cap (housing cartridge)
there should be a little cap covering a allen srew in the front or back of the handle it sometimes looks like the hot or cold sign or chrome pop that off and loosen the screw and pull off the handle there should be a nut loosen that and pull up the cartridge you might be able to find one at home depot be sure to turn the water supply off
May 20, 2009 | American Standard 2175.502.002 Colony Soft...
Handle stuck; How descale w/o ruining chrome finish
WD-40 will not harm the chrome but it you have liquid wrench, it would be better lubricant as WD 40 chemicals are actually a cleaner.
A descaler you need to be careful here. Lime-away or CLR is a popular choice but you need to read the label on chome products.
Jan 25, 2009 | American Standard Collection 4241.002...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
American Standard 4175.200.002 Colony Single Control Kitchen Faucet, Polish Logo
513 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
