Question about Miele DA 249-4 Kitchen Hood
Miele da249-1 motor not running, light comes on
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Which light comes on? Indicator light or work lights?
Posted on May 06, 2017
Miele da249 motor stopped running, light comes on, relay on cpu clicks. How to test if it is the motor or the cpu?
They do not use a CPU. I would check things like is the fan free to spin? Check the capacitor with a meter. Check for power coming out of the power board. Most likely the power board faulty. The motors rarely fail. Also check connecting plug between the push button board and the power board. Just drop the flue cover off and make sure it is plugged in correctly.
Jan 02, 2014 | Miele DA 249-4 Kitchen Hood
The inlet drain light and rinse aid light have both come on and the dishwasher is humming but not working. Any suggestions?
Hello Mark,
You didnt say so but i think it is a Miele dishwasher,its the only brand i know of with a Intake drain light
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced, if you contact via their website,they may send you that tool. To use it remove lower rack and pump filter and insert into the side of the pump hole(you will be able to see that hole with the filter removed) and rotate it back and forth at first it will resist then should quickly break free,if it is had to turn the pump/motor seal kit would need to be replaced.
Gene
Aug 07, 2011 | Dishwashers
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
I have a Miele turbo plus solaris and the red warning light is on. This prevents the vacuum from working. I have changed the bag so I am not sure what to do?
I had this problem with a different model. It's caused by a thermal cutout switch in the motor. My problem was a result of a filter being removed and the bag not seated correctly, hence dirt got into the motor and clogged the turbine, reducing airflow through the motor and causing the over heating.
If your motor runs at all, you probably have a blockage. Replace the filter inside the bag compartment just before the motor vent. Check the hose isn't blocked. Check the exit air filter.
If your turbine is clogged, it's a big disassembly job best done by a professional. If you really want to know how to cure it and feel you can tackle it yourself, email me. alan_at_alanjohnston_dot_com.
If your motor doesn't run at all and the light just quietly comes on, you have a break somewhere in the thermal protection circuit, either in the wiring (unlikely) or inside the circuitry buried inside the motor itself. I had an open on the thermal switch where the combination of heat and vibration deoldered the thermal switch from its board.
Hope this helps.
Alan
May 21, 2010 | Vacuums
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Intake Drain Light
My Miele Incognito dishwasher kept getting an error with intake/drain light. The light flashed 5 times. Phoned Miele Technical Support to investigate the problem. The problem is that a seal in the bottom of the dishwasher has failed and there was water in the motor pan. Currently, $175 service charge for the technician to come look at it.
I don't want to spend $175+ to have them replace a 75 cent rubber gasket that I could replace on my own.
Feb 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
Miele DA 249-4 Kitchen Hood Logo
103 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Steve
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
