Question about LG Dryers
Lg dryer reset button - LG Dryers
Is there a reset button on the LG condenser dryer, serial number 012KWRE00206
There is no reset button, but there is a thermal fuse that is housed within the cabinet.
Mar 20, 2016 | LG Dryers
LG Dryer buttons frozen 'on'
Did it run for awhile first? Ours ran & ran & never turned off. I manually unplugged it. Eventually, determined it was the thermostat that was triggered. First time, the repair man replaced it. Second time, he just hit the red "reset" button in the back. (LG told me over the phone there was no reset button, but not true.) You have to remove a panel in the back (carefully, it's sharp) and reset. Not sure this is your problem, though, from the sound of it. Worth a try. Now I don't run ANYTHING when the dryer is on (not even the washer..which is a pain). Seems to help.
Mar 05, 2014 | LG DLEC855 Dryer
Reset button
There is no reset button on this machine, by turning off the power for about 2 to 3 minutes the memory on the control board will clear.
Failing this, there is a problem on this control board.
Jan 01, 2014 | LG DLE2532W Electric Dryer
LG DLe0442W Dryer working but no heat at all.
Check the heating element. That is were the fault is coming from.
Jan 09, 2012 | LG DLE2532W Electric Dryer
Where is the reset button located on the machine. Dryer is not heating
I'm not too sure about where the reset button is, but if it's getting gas and it's not heating, there might be a problem with the igniter.
Mar 07, 2011 | LG DLG5932W Gas Dryer
My LG gas dryer has had the thermostat sensors replaced and reset twice already, but after a few loads it stops producing heat. I have taken off the new exhaust outlet as I think the flapper may be...
You will need to disassemble the top panel, the control board, the front panel and the drum assembly to get access to the reset switch. LG has posted that once the button has tripped, it is recommended that it be replaced rather than constantly resetting the button.
Good luck.
Sep 28, 2010 | Dryers
No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
lg is a little more tricky to get apart, but ther are a few screws infint of the lint filter housing, as well as afew under the main lid."pop" the top by inserting a screwdirver into the clips located on either side perhaps 3 inches in or so.and then trher are a few phillips head screws that willl release the front panel,along the bottom right side is a few thermostats as well as a heater asssy, one of the thermostats have a red button protruding from betwwen the 2 wires, try pushing it in.it will reset the thermostat(its gotten too hot and "popped" for safety reasons...CHECK YOUR VENTING
Mar 29, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Washer/dryer has stop
There is no reset button but it could be that a wire has come loose from all that thumping.  Check the connectors to the control board and to the display board to make sure that they're connected properly.
Jul 01, 2006 | LG WM3431H Washer and Dryer
Dryers Logo
115 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
