Question about Kohler Home
LOOKING FOR GASKETS & BOLTS BETWEEN TOILET & FLUSH BOX
I want to replace bolts & gaskets between the toilet and the flush tank on a Kohler toilet. The present gasket is inside the hole in the tank. I am having trouble finding finding replacements. Please help.
    Genius:
  • 1,605 Answers
Go to any howm center, plumbing section. The replacement gasket is not the same as the original, however, they do fit. The other choice is go to Kohler resaller.
Posted on May 21, 2009
Toilet tank leaking
Hello David McInnis,
There are Three basic opportunities for leaks from the classic TOILET TANK DESIGN (separate BASE & top-tank)... around the FLAPPER VALVE alone... Typically the flapper valve & two hold-down screws. These CANNOT be repaired without removing the entire tank. GREAT CARE should be used to not FRACTURE
the mated surfaces by OVER-TIGHTENING.
This is a great time to FRESHEN UP all the
Perishable gaskets & seals... and while I NEVER advocate using any ABRASIVES on gloss finishes... Pumas stone seems to be the FINAL TOUCH in a total renewal
(to REMOVE the built up (very unsightly
TOILET BOWL RING...
Amazon com toilet bowl pumice stone
ADDITIONAL PARTS:
- Water fitting to FILL VALVE (compression fitting).
- FILL VALVE through tank (gaskets)
- Flapper Valve base, gaskets & bowl interface ring
TO Make sure all the surfaces are clean an firmly
positioned and it is not LEAKING anywhere... place
clean dry paper on the floor behind the bowl
(under the tank).
EACH/EVERY drop will leave a mark...
Do NOT over-tighten any fittings!!!
If the WALL VALVE is less than NIMBLE... also a great opportunity to UPGRADE TO A QUARTER TURN
BALL VALVE... A little shopping will find you EXACT VALVE CONFIGURATION...
Hope this helps.
LASCO 04 3809 Toilet Tank To Bowl Bolt Kit Brass Bolts with Washers Hex...
Fluidmaster 6106 2 3 4 Inch Tank to Bowl with Three Bolts and Gasket...
BrassCraft G2CR19X C1 1 2 in NOM Comp Inlet 3 8 in OD Compression Outlet...
Kohler 1068031 Fill Valve Flush Valves Amazon com
Apr 02, 2017 | Plumbing
Toilet tank to bowl small leak
You need to replace the tank to bowl nuts, washers, and gaskets as well as the flush valve gasket. One word of caution. When installing the new bolts to hold the tank in, place a rubber gasket under the washer inside the tank, and also one on each bolt under the washer underneath the tank. If you omit the one under the tank you may end up cracking the tank when you tighten it down.
Jan 16, 2014 | American Standard Cadet 3 Right Height...
Leaky Seal
By leaking do you mean onto the bathroom floor, or is water escaping out the flush valve (the part that the Hydroright is seated in) into the toilet bowl. If the former 1) check toilet tank mounting bolts/gaskets for deterioration or looseness. These are usually 5/16"x3" brass bolts with rubber, plastic, and metal washers with a nut. They can be seen protruding through bottom of tank. 2) check flush valve and rubber gasket between tank and bowl. The flush valve is the one that the refill tube goes into and the hydroright seats into.
If you are only leaking water into bowl I would suggest the blue dome gasket ( part of Hydroright kit) is not properly seated properly into flushvalve, and you may have to re-install hydroright (the instructions explain how to remove and re-install) . I broke my existing/old flush valve at the base when trying to install my Hydroright so maybe it was fortuitous that it broke and I had to install a new one. Hope this helps.
Dec 15, 2013 | HydroClean Hydroright Dual Flush Converter...
What could be the cause of leak after installing new gaskets and screws, above back/rear screw? 1) not from screws 2)tank not cracked 3)securely tightened all 3 screws 3a)hand tightened(only)large...
Hello, W/D here.
Most probably, the tank-to-bowl gasket has not seated properly. They are usually neoprene, and tend to bight on the bowl socket rather than to slide into the socket where it can be compressed properly. Remove the tank bolts and look at the gasket. Re-install, using a water based lubricant on the bowl side, with the gasket installed on the tank flange. Wiggle the tank and gasket back and forth a few times, and the gasket will start properly into the cast socket on the bowl. Install the bolts and tighten to finger tight. Wiggle the tank a bit more, and level the top. Tighten the bolts uniformly.
You mention that the flush valve was hand tightened only. If this gasket is not snug (a bit more than hand tight), a leak can occur there as well.
Best regards, --W/D--
Apr 05, 2011 | Kohler - Toilet - Two-piece - Highline -...
Need step by step explanation of removing and replacing a triangle toilet gasket.
Turn off the water to the fixture.
Flush the toilet and hold the handle down to let as much water out of the tank as possible.
Sponge the rest of the water out so the tank is dry.
Remove or undo the water supply tube from the fill valve.
Remove the three bolts holding the tank to the bowl and remove the tank.
Replace the old seal with the new one and reverse the whole process.
You should be good to go.
Good luck.
Mar 06, 2011 | Kohler KOHGP51487 Authorized Original...
Replace toilet tank bolts
Go to a plumbing supply house and get 2 or 3 bolts, 2 or 3 rubber sleeves for the bolts, and a new rubber gasket to go between the tank and toilet. Turn the supply water off, sorry, but, you don't know how many people don't do that. Disconnect the supply line from the tank. Flush the toilet, to remove water from the tank. Unbolt the tank. On the back underside of the toilet, you have 2 or 3 nuts to remove, depending on the toilet. Lift off the tank. Turn over the tank and set it on a towel. Now, gently tap down the bolts. Turn tank over and pull out the bolts. Turn tank back over and remove the tank and bolt gaskets, just push them in. Turn tank over. push in the new gaskets. Replace tank gasket, and gently tap down new bolts. Remount the tank. tighten the nuts, be careful, always tighten the nuts about the same. never tighten one all the way, and then another. YOU can crack the tank when tightening. Just nice and snug. Re hook the water supply, and turn on. Always check for leaks. If dripping, just tighten a little more. Just remember to tighten the all the nuts a little at a time. Keeping the tank level when tightening.
Dec 24, 2010 | Sterling 402315-0 White Windham Two-Piece...
I just install a toilet, when I go to flush it. the water come out underneath the toilet tank?
You did not get things sealed properly...Make sure that the foam seal is in place and the the bolts are not too lose...
It also is possible to crack the tank if you make the bolts too tight...
heatman101
Apr 21, 2010 | Kohler K-3422 - Wellworth Elongated...
I have toilet with no visable clog but when I flush water fills the bowl and overflows? How do I fix
Something is stuck inside of the toilet. About the only way to get some of them out is to take the toilet up. Shut off water to the toilet and flush it one last time.You need to use a plunger and push all the water you can out of the bowl. Remove the bolts that hold it to the floor. Youll have a little left over water you'll have to clean up after this next step so get something to soak up water. It may be easier to remove the tank now than to take a chance on damaging the gaskets. Just going to have to turn the toilet over and over and over and see if something falls out into the bowl. To repair this damage you're going to have to clean off the wax ring (messy Job) and get a new wax ring. They're pretty universal 3 and 4 inch are the same. PUt the wax ring onto the bottom of the toilet then set it back over the bolts that hold it to the floor and tighten it back down. Replace the tank and tank gaskets if you took it off. When I fixed mine I found a AA battery inside. That was all it took to plug it up every time you flushed toilet paper.
Nov 29, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Water leakage from the gasket under the flapper
You will need to replace or repair with new gaskets your flush valve mechanism. "To do that you need to take the tank apart from the bowl. Have new toilet bolts and flush valve or flush valve gaskets at the ready when you take the tank off. (you will also have to unhook the fill valve when you take the tank off.) Another possibility would be a cracked tank that is causing the leak in that area but that is rare.
Oct 07, 2009 | Eljer 111-1000-00 White Kindergarten...
How do I install a gerber 21-375 Toilet? It came with no instructions.
The Gerber Ultra Flush Back Outlet toilet, that uses 1.1 Gallons of water to flush?
Just like any common toilet. Install the tank to the bowl of the toilet, set the toilet, install the flush mechanism in the tank, attach the supply line.
1.MAKE SURE you put the two plastic U-shaped spacers on the back of the bowl!
2.Install the round rubber gasket in-between the tank and the bowl.
3.Set the tank down on the bowl. Make sure you have the round gaskets that go up under the bolt heads, then insert the two bolts into the tank, and through the bowl. NOT installing these will cause a leak!
Tighten these bolts down, until the nuts are JUST touching the tank. (There is a flat washer that goes under each nut)
DO NOT tighten one bolt all the way, then tighten the other bolt!!
These bolts MUST be tightened evenly. Tighten one turn on one bolt, then go to the other bolt.
DO NOT overtighten, or you will break the bowl, and/or the tank!
Make sure your toilet flange on the sewer pipe is in good repair, and clean, from the old beeswax ring. It can be messy, even using gloves. Use a flat painters stick to help remove the old wax ring. Scrape off into a old can. The wax thin residue on the floor and flange is fine.
Set the new wax ring in place, remove the plastic liner that comes with the ring. DO NOT leave that thin plastic liner! It's just to install that wax ring!
Install the bolts that hold the bowl to the floor, or reuse the old bolts if they are in good repair.
Tighten EVENLY, and don't overtighten! You can crack the bowl.
Now install the toilet mechanism in the tank.
Here is a 1 Page, Tank to Bowl Installation Guide from Gerber. It is a PDF file. Let it download ALL the way before looking at it.
http://gerberonline.com/fileLib/Toilets%20Ultra%20Flush%20IS.pdf
Should this direct link not work for you, here is the page it came from,
http://www.gerberonline.com/Catalog.aspx?categoryID=2204&itemID=3514
It's on the right side -> Installation Instruction (PDF)
Jul 02, 2009 | Gerber Blades Gerber Ultra Flush White ADA...
Home Logo
299 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
