Question about Crosley CAWC529JQ Top Load Washer
Washer makes grinding noise when it agitates
The washer fills and drains fine. It makes a loud grinding noise when it starts agitating. After a minute it stops, making the noise only intermittently. The same thing happens during the rinse cycle.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Problem Solver:
  • 10 Answers
Check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Posted on Jan 02, 2014
  • Susan E Bennett
    Susan E Bennett Mar 08, 2015
    Machine has a direct drive
thaurfen
  • 623 Answers
SOURCE: extra loud noise when spinning
most likely the main spin bearing at the top of the transmission just below the spin basket and seal
the bearings dontjust go out for nothing either,you will need to be replacing the tub kit seal also
not the easiest of repairs,may need special tools to remove the seal nut assembly...
Posted on Mar 17, 2009
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
freetek
  • 5568 Answers
SOURCE: I think my washing machine just died!!!
The transmission could well have caused the failure but the smoke was almost certainly from the drive motor.
The cost of replacing them both is probably prohibitive.
Unless you are really into preserving the environment (and your machine) it may be time to retire it.
I don't know where you are but I would estimate the cost of the transmission at $120-150 US and the motor at $60-100 only for parts.
With the growing complexity of many machines, I tend to stick with those using older technology and keep my fingers crossed that they have not cheapened the quality too much.
As we equipped a new house 3 years ago, I did a lot of research and found essentially no machine that was 'bullet-proof.'
We finally bought Roper machines and have not had any complaints to date but have a small household so not much stress on the machines.
Roper has been owned by Whirlpool for years but my experience with direct Whirlpool branded machines really stinks; refrigerator died due to a low-voltage condition that occurred while we were gone requiring a new comperessor, washing machine thatate its transmission in < 3 years, etc.
All were purchased new.
Posted on Jun 21, 2008
localwonder
  • 6784 Answers
SOURCE: agitates and drains but will not spin
Hi, there is a lid pressure switch that controls the motor during the spin cycle. if the lid is up, it will close open the circuit that controls the motor and it will shut the spin down.
Now, if this lid switch is broken or lose, it will not allow the spinning action at all. your lid pressure switch is damaged or lose at this time. i recommend inspecting this switch that is located under the lid rim. check the wires and connection clips for a lose fit. if the wires and clips are in good condition, this Will confirm the switch failure. replace in this case. i will link you to a replacement switch you can order on line if you choose.
CLICK HERE.
Posted on May 15, 2009
SOURCE: Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Posted on Jan 09, 2010
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Grinding noise when it goes to agitate or spin.
gramps Most likely the problem with your washer is worn out motor drive coupling. You can buy it here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.547094027&type=10&subid= If you need help to replace it, let me know. Gendos...post back
Feb 05, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
502 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
