Question about Clarion DXZ775USB CD Player
Hi, I have an 12 inch subwoofer who doesn't want to play. It play when i plug my ipod through the amplifier and i know that the problem comes from my head unit. Everything is right connected behind th
Hi, I have an 12 inch subwoofer who doesn't want to play. It play when i plug my ipod through the amplifier and i know that the problem comes from my head unit. Everything is right connected behind the radio. Is that possible that there is a fuse on the radio to play the subwoofer? Any advice to solve my problem? Thx you and sorry for my english.
    Novelist:
  • 149 Answers
The i pod should play through your head unit when you scroll through the SOURCE button and land on AUX.-thats how it works on mine but yours might be different. Good luck
Posted on May 21, 2009
Tip
How to connect my iPod to an Amp & Subwoofers
<p>If your iPod to your amplifier or subwoofer that connects to a stereo receiver. This can be done through an additional cable. <br /> <p><br /> <p>1. Locate the auxiliary input on your stereo connected to your amplifier and subwoofer. These entry, small and round is labeled "AUX". Usually this entry is available in front of the stereo, but some devices can be found on the back. <br /> <p><br /> <p>2. Connect another cable to the auxiliary input of your stereo. <br /> <p><br /> <p>3. Connect the other end of extra cable to the headphones of his iPod. <br /> <p><br /> <p>4. Press the "AUX" input button on your stereo. Now when you play a song on your iPod you listen to them on your speaker system including subwoofer and amplifier. <br />
on Aug 09, 2011 | Apple iPod touch
Amplifier when i plug the rca cables from the radio to amp the subwoofer is jumping and going out of control with no music playing
Make sure the amplifier is properly grounded. If the ground is good, hook an ipod up to the rca's to test.
If the problem goes away, you may have a problem with the headunit. If the problem remains there may be something wrong with the amp.
Feb 28, 2011 | Car Audio & Video
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
How do i use my ipod to play through my 12 year old Bose Acoustimass series 5 system
You don't connect an Ipod directly to any unpowered speakers since they need an amplifier between them and your source. Presumably, your speakers already have an amp source? Then what you need to know is how to connect the Ipod to the amp. Without specifics, I can only offer general advice. Get an adapter for the Ipod headphone it to make it compatible with either an RCA input or a headphone jack.
Nov 27, 2009 | Bose Acoustimass 15 System
I have a roland keyboard mixing amplifier, KC-550. With an ipod plugged in, its only playing one channel, regardless of which channel I plug into, and the keyboard is also not sounding full. Not sure if...
The KC-550 is a MONAURAL amp and since the Ipod emits STEREO you have to use a special cable to MIX both the left and right from the Ipod into a single, monaural signal.
You can MAKE a cheapy mixer that will serve your purpose by using a series resistor, say 1K from each of the two Ipod output channels to go to the single mono input to the KC-550.
I would build it this way: Find an old IPOD cable or any 1/8 inch stereo cable and seperate the two wires and the shield. In a 1/4 inch plug, connect the shield from the Ipod cable to the shield (barrel sleeve) of the 1/4 inch plug. Connect one lead of each of TWO 1K resistors to the TIP connection of the 1/4 inch plug. Connect each of the two signal leads from the Ipod to the two remaining floating resistor leads. Insulate the splices.
DON'T forget to put the shell for the 1/4 inch plug over the cable before connecting the cable to the 1/4 inch jack. All parts should be readily available at Radio Shack.
I don't know that I have ever seen a suitable ready made mixer cable for this function.
Nov 21, 2009 | Roland Audio Players & Recorders
I need instructions connecting my car subwoofers
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Mar 08, 2008 | Car Audio & Video
MY AMPLIFIER
HI SOUFBOY , Theres a few things you need to check , First make sure that your amplifier is getting an audio signal form your head unit,Check all the wires for breaks in the amplifier input, secondly make sure that your 12 inch woofers are still connected to the amp check all the wires . Thirdly check your woofers are they blown ? . The best way of grounding your amp is by scrapping all the paint on a spot on the car body inside the trunk or wherever you have it and making sure the ground wire is securely screwed onto the car body on that spot ..
Mar 19, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Clarion DXZ775USB CD Player Logo
98 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
