My sony bravia kdl-40ex723 has a distorted picture..the screen goes up and down. what should i do? please help?
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
Sounds like a main bard fault. Contact the authorized service center for Sony. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Jan 02, 2014
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Flat screen
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Posted on Apr 02, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
My Sony Bravia picture turns green.
check cable, if its using an HDMI, replace it: if component RGB cable, reseat or replace.
Oct 03, 2015 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Bravia problems sony tv
Just visit the site given below. It has screen shots to defective Sony Bravia. Compare it to that of your TVs' and make sure about the fault. In most cases, the fault you described here sill be repairable.
Nov 20, 2013 | Televison & Video
Sony bravia kdl-52w3000 picture and sound works for a while, then screen goes blank, sounds goes out
Does set do this on all inputs including one with a DVD unit connected and playing? Answer will at least narrow possible reason down a bit.
Apr 19, 2012 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Black line going down middle of screen and one side of picture darker also picture sometime is distorted on bottom
if the line is pixel thin, it could be a bad lcd panel. if it is a wider bar, it may be in the video circuitry. many of these sony tvs had bad panels, and sony has extended the warranty. call up sony with your model and serial # and date of purchase and try to get them to help you out, that is your best course of action. let me know if you need more troubleshooting assitance.
Jun 01, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-46XBR 46 in. HDTV LCD Television. I have a problem when the unit is switched on. The screen has 2/3 lines running across it. The picture stays like it for about 10 mins then goes back to...
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 19, 2010 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
