Question about Lands Phones
Want replacement cartridge
This phone was purchased in about 1976
    Problem Solver:
  • 6 Answers
Battery's do you have the voltage information on the old battery or the inside of the battery enclosure available if so take down these numbers.
Output voltage and polarity positive negitive as well as required amperage. Should be a two pin connector that you can find on most phone batteries just head down to your local hardware store and find a battery that either matches these voltages or is slightly above them. Should allow you to use your phone again but you may run into problems closing the battery compartment and or your phone may die after a shorter period of use however since you have had it since 1976 thats a really good run for a phone and you shouldn't be too concerned.
Posted on May 20, 2009
I require simple wiring diagrams for a 1976 F150 pickup.
Use a test lite on negative side of coil, engine cranking, the lite should pulse?
It appears the vehicle has electronic ignition, There is a separate ignition module. In the wiring diagram, I can't guarantee the wire colors. The older my wirings diagrams are, it seems, the less accurate they are. I hope it is readable, If no spark, I'd check the ignition system, Check fuses--fusible links--battery connections.
Oct 02, 2016 | Ford F-250 Cars & Trucks
Does this model panasonic fm/am radio stero phone need a cartage for the needle.
As it was purchased second-hand, I would replace the cartridge and stylus with a new one anyway. You can put the model number of the cartridge (found on it) into Google search. That should come up with the right one. You can basically fit most types of cartridge, as long as the you get the right type. IE: A magnetic one if the unit has a cartridge pre-amp built into. Or the Ceramic type etc if it hasn't.
Aug 30, 2015 | Panasonic Audio Players & Recorders
How to replace 1976 oil seal on a 305 chevy monte carlo
Need to know which oil seal...If it is a Rear Main Oil Seal you will have to remove Trans or Engine...It is easier to remove Trans...However If it is either front or rear main engine seals it would be a good idea to just remove engine and replace Both front and rear seals of engine ..,Also oil pan gasket b cause of vehicle age and or mileage...BUT I need to know which seal and I can guide you through the procedure of replacement...
Dec 03, 2014 | 1976 76 Chevrolet Monte Carlo Light...
New replacement black nose for 1976 micky mouse phone
Did you ever find a replacement? I too am looking for one.
Pokerbunny1@gmIl.com
Feb 09, 2014 | Disney Classic Mickey Mouse Telephone
Black cartridge is new. registers low ink level and does not print at all.
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Mar 17, 2011 | Dell 962 Photo All-In-One InkJet Printer
Hey i have an problem with my honda goldwing 1000 1976 it only runs on the 2 left cylinder when it stands still but when i accelerate it runs on all 4 please help me Thomas from dk
You should try replacing all four of the spark plug caps. You can purchase inexpensive NGK spark plug caps for around $5 each. It sounds like the resisters in two of your caps are burnt out. The caps are screwed on to the end of the wires. Take off the double water cover over the caps, grab the wire firmly, and turn the cap counter clockwise. It will turn right off the end of the wire. If the end of the wire is stripped clip 1/4 inch off the end of the wire and screw the new cap on. If the points are giving you trouble, the points and condenser can be replaced with a compact electronic ignition for about $200 available through Parts Unlimited in the U.S.
Mar 06, 2011 | 1976 Honda GL 1000 (K1)
I have all new Q39**A series cartridages in my 2840 but the printer wll not recognize them and will not print in color. When I replace the Q3972A with a new Q3962A it recognizes the cartridge and tells me...
Clean the terminals of the cartridge. use an eraser and gently rub the terminals until the gold terminals shine. Now try the cartridge.
if the problem still persist. then you can go for replacement of the cartridge from where you purchased it. The problem is pure technical and you deserve a replacement
Nov 30, 2010 | HP LaserJet 2840 Printer
I alrready replaced the ink cartridge but i am still getting the message "ink catridge missing or damaged". What can I do?
Did you refill the cartridge ? Most of the times when you get this error message it means the cartridge was refilled by the user instead of purchasing brand new ones or that the copper contacts (gold coloured strip) on cartridge could be defective.
Take a dry paper towel & wipe the copper contacts on the cartridge. Wipe the copper contacts inside the cartridge holders (where your cartridges sit inside the printer). Reconnect the power supply to the printer & try printing. If still doesn't work, call Lexmark Tech Support on 1800 332 4120. They'll fix your problem & in case they're not able to, they'd ship you a replacement cartridge, no charges at all. Its worth the wait on the phone waiting for the tech support.
Oct 31, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
I need directions on how to replace my ink cartridge on a HP officejet v40. My husband purchased this printer, but I don't know when, and he has since passed away. The support on the phone wouldn't help...
Hi, normally when you open the printer the ink cartridges will go to the centre and you can unclick the cartridges to replace them. On some printers you need to press a button which brings the cartridges to the centre so you can replace the cartridges.
May 13, 2008 | Office Equipment & Supplies
Lands Phones Logo
49 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
