Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Bogs at low rpm and uses lots of gas - Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
  • 3 Answers
Change you coil the one not sparking!!
Posted on Jan 03, 2014
2005 dodge magnum, sometimes bogging down , mainly inner city travels When it boggs down and I have to give full acceleration, it will take off fast afterward and a strong gas smell is give off.
Hi Kelly:
Sounds like it's getting too rich a mixture at low RPM.
The full acceleration is getting lots of air and essentially purging the bad mixture.
I'd recommend checking on how long it's been since a "tune-up".
Things like changing the air filter and spark plugs.
A dose of "tune up in a can" through the fuel system has been known to clean up a gummy carb or fuel injection system.
Jun 25, 2015 | Dodge Cars & Trucks
No Check Engine Light illuminated, when I press the gas it bogs down and will not exceed 3000 RPM. No powere
Millage, make , model ......
Catalytic converter clogged ?
I could guess all night but need more info.
Feb 09, 2015 | Cars & Trucks
Lots of gas consumption on 2001 polaris xc 600
if your air filter is clean then I'd check the float and float height in the carb
Jan 02, 2014 | ATVs
1991 KDX 250 uses alot of spark plugs.splutters and bogs down after riding at low rpm. plug comes out wet and black with no spark. new plug fixes problem immediately but happens again after about 5 litres...
have u tried a hotter plug it worked on my car, also i add lead substitute to gas .try a performance coil and switch to electronic ignition also i did this to my bike and it ran a lot better.
Mar 20, 2011 | kawasaki KX 250 Motorcycles
2001 nissan maxima gle it bogs down when i press on the gas,idles low at .5 rpm,dies when i start it i have to keep my foot on the gas,lights run dim when i come to a full stop it has 155,000 miles
Hi and welcome to FixYa!
As a first course of action, I strongly suggest that you replace the MAF (mass air flow) sensor and the TPS (throttle position sensor). If the MAF and TPS is faulty the RPM tends to go down or goes erratic. The MAF and TPS is located at the throttle body which is secured by small screws or bolts. It is visible which can easily be seen.
Once replaced you'll be good. Hope this helps and thank you for using FixYa! Have a good one!
Feb 27, 2011 | 2001 Nissan Maxima
2004 sportsman 600, bogs down bad at half throttle.
Check that your choke is working correctly
Your timing may be way off as well
Mar 08, 2010 | Polaris ATV
Saturn vue2003 now power low rpm
yep a stop up fuel filter.will cause low power.also bad gas and if transmission fluid is low.transmission will starting slipping. causing low power.check transmission fluid if it looks black has burnt smell.change transmission fluid and filter.
Nov 21, 2009 | 2002 Saturn VUE
I have a Yamaha DT50W with poor low end power. Engine runs fine at high rpm but bogs at low rpm and will not pull up hill without reving engine and clutching. Engine responds normal with no hesitation on...
yep sounds like it needs rings the dt50w usualy has lots of torque down low so if you are having ti rev the **** out of it somthing is not right only other option would be that the previous owner messed with the sprokets to get more speed but lost low end torque
good luck
Oct 17, 2009 | Yamaha DT 125 R Motorcycles
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
52 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
