How to remove dvd stuck - Televison & Video
Memorex cd/dvd player won't open. I can't get my dvd out
It may be necessary to disassemble your player to get access to the drive for removal of the stuck DVD.
Jun 18, 2016 | Memorex Mvd2047blk 1080p Hdmi Progressive...
Need to get stuck DVD out. How do I remove the DVD player?
Before removing the DVD player...1st try inserting an old DVD disc under the stuck one, and press eject...this usually works...hope this helps.
Sep 24, 2015 | 2006 Chrysler Town & Country
How do I remove stuck DVD?
If this is a combo unit the first thing you have to do is remove that dvd from inside the player. Open up the unit and do the deed. THEN see what happens. Often when the player gets jammed or whatever, it will render the rest of the set useless until the hassle is removed. In this case get that disk outta there.
If still nothing disconnect the power line that feeds the dvd to see if that has any effect on overall tv operation.
Sep 05, 2015 | Sylvania Televison & Video
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
How to remove a dvd stuck in the dvd player in a gmc 2004 envoy
Most DVD players have a tiny hole on the front to mechanically push the internals to eject stuck DVDs. If the player does light up, sometime a thump with your fist is enough to jolt the mechanism. Failing that, you have to remove the player to get the DVD out.
Mar 01, 2014 | Cars & Trucks
Disk storage medium stuck in DVD-Rom.
If there is a disc stuck in the drive, removing the drive from the case is not necessary. Just take a paperclip and stick it in the manual release hole in the front of the drive.
Jun 22, 2009 | Dell CD-ROM DRIVE 8X 7G828 DVD Drive
DVD stuck in player with no power
you have to unpower it and remove the screws from the cover and then remove the screws off the cdrom/dvd player.
Apr 08, 2008 | Televison & Video
Dvd stuck in player. Dvd won't play. None of the buttons works. Nothing works. Can't watch tv or anything.
Had the same problem. After a couple of times of removing the DVD player and manuelly removing the DVD I called for a RMA and they fixed it, but they say the problem was that  I had another DVD in the player. ???
Oct 16, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
DVD stuck in player
take top piece of the dvd player. there are about 7 screws.  5 min fix
Aug 11, 2007 | Samsung HT-DB600 System
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
