Question about Water Reservoir
Watersoftener salt tank keeps flooding
Our Kenmore salt reservoir keeps flooding with water ever few days. We clean the venturi and drain the tank with the reservoir by unplugging for a few hours, but a few days later the reservoir is flooded again. This has not been an issue for the few years the unit has been in use. How do we resolve?
    New Friend:
  • 3 Answers
Sounds as if the head has a valve sticking, Need an overhaul kit that has new paddle valves with screen and injector also. Unplug unit, put into by-pass (3 valves above it) then manually rotate cam to depressurize head and tank, follow kit instructions to overhaul, or you may want to call a plumber.
Posted on Jan 02, 2014
3/4 full of salt, but no soft water, and water in the salt container
You didn't specify the type of softener, however if it's a Kenmore, GE, ECO Water or similar (usually under $500), the vortex/venturi, probably needs cleaning. (If you have iron in your water, you need to clean this about every 6-12 months, depending on how many ppm your water has).
But it's an simple & easy procedure. First remove the cover of the softener (usually held on by 2 clips in front, 2 in back).
Once the cover is off, on the left side of the valve you will see a conical-shaped plastic part. (Usually gray, but not always). You will need to unscrew this (it's ok if water is still on, it's not under any pressure unless it's recharging) and clean the screen inside.
Most likely the screen will be caked with iron oxide (rust). I use a rust dissolver (such as Iron Out or any product designed to dissolve rust, but this is strong stuff, wear gloves or wash you hands immediately afterwards) and let the screen soak in that for 1/2 hour. If needed, you can speed the process along by using an old toothbrush and clean the screen, then soak a little longer, brush again, etc.
Once clean, replace the screen (mind the O-ring) and cover (hand tight is sufficient). Start a manual regeneration and clean the resin bed.
-If you decide to remove the rest of the parts in the vortex/venturi, be very careful not to lose anything. A few of these parts are very small. There should be a diagram of how the parts go together in your owners manual and on the machine itself. Usually these will not need cleaning, but doesn't hurt to go ahead and make certain. As to the two rubber parts with holes in them, the one with the larger hole goes on the bottom, and on both, the rounded side goes up. Watch carefully when you disassemble and remember so you can reassemble in the correct order with done.
As you have water in the brine tank (salt tank) keep an eye on this to prevent a salt bridge from forming. This is more prevalent with rock salt than pellets, but can form with any salt.
(I would strongly recommend you never use "rock salt" in any softener. It's full of dirt and you will absolutely need to clean out the brine tank at least annually or the dirt will end up being drawn into the softener. I use a good quality of salt pellets with an "red out" to maintain the resin against iron. These are usually good up to 2 ppm iron, anything over this and you should use a 1/2 box of Iron Out or similar, every 6 months).
If you suspect a salt bridge has formed, try pouring hot water onto the salt at one spot. This will dissolve the salt in that spot and form a "hole" in the salt. (Hot water dissolves salt faster than cold).
Once you break through, use a broom handle to break the salt surrounding the hole and it will collapse into the bottom of the brine tank. Suspect a salt bridge is the machine runs properly, but no soft water.
May 13, 2016 | Water Dispensing & Filtration
My daughters water softener filled up with water and now is losing water and salt on the bottom of the thing.
Probably need to clean the vortex / venturi. If you have iron in your water, you need to clean this about every 6-12 months, depending on how many ppm your water has).
It's an simple & easy procedure. First remove the cover of the softener (usually held on by 2 clips in front, 2 in back).
She probably does NOT need to replace this unit. What you perceived as a leak may only be water backing up in the brine tank and leaking out of the overflow.
Mar 08, 2016 | Morton Salt Inc 15010000 - Water Softener...
Water Softener is 1 month old. Salt water up to the 4 mark after recharge cycle. How much brine (volume, please) is supposed to be drawn out of the salt tank upon recharging?
it depends on the concentration you have set in the controls if you set it to a high percentage ( hard water) it will draw out about 40 lirs of salt water
That is to say , if you have the reservoir filled to the overflow hole before , then it will empty the reservoir and may require you to fill it so that it keeps sucking until it finishes the setting time
there will be volumes setting in the user hand book that you adjust to for the hardness of the water
Feb 01, 2016 | Kenmore Ultra High-Efficiency Water...
Brine tank fills but doesn't draw it back into the water sosftener
Your injector is stuck. Your manual should show you, at the least,
a diagram; you'll need to clean out the center of the injector and lubricate the seals or o rings with silicone grease. You cannot use Vaseline; it'll attack the rubber. You should bail out the excess water from your salt tank. After you've got rid of the particle of dirt from the venturi in the injector and lubricated the seals or o rings with silicone lubricant, reassemble. Three manual regenerations over the next three days should bring your softener back to full function.
Mar 01, 2015 | Kenmore 350 Series Water Softener
Brand new softner full of water
Your injector is that part of your control head that switches to allow salt brine to be sucked out of your salt tank (during regeneration) or shifts a couple of mil to add water to your salt tank to make brine (at the end of the regeneration). Your injector is either stuck or the venturi in it is blocked up with some kind of debris. Your manual should tell you how to clean it or, at the least, diagram where it is and how to access it. If you lubricate it you must use a silicone based lubricant; Vaseline or oil based lubricants will make the rubber O rings old before their time.
Sep 09, 2014 | MORTON SALT CO 8708 System Saver Water...
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
Kenmore Water Softener does not advance through cycles
You can send to the company for repair too ! If it sill under warrenty to fix it and aslo don't try the step anymore it might cause some parts damage that the service provider my charge you more.
Dec 09, 2013 | Washing Machines
My kenmore electronic fridge keeps building frost on the back wall i cleaned out the reservoir in the fridge part where the water drains and ran some hot water through and it worked ok for a couple of...
check defrost timmer or defrost heater if the timer is working find the timer and turn the knob tell it clicks if it defrosts in a few min then you need a new timer or turn it manualy every few days
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore water softener tank flooded; no soft water
Well, there was no good solution. I capitulated and called in a professional Sears repair guy. He was as baffled as I about what was wrong. We just started throwing parts at it until the problem subsided. We finally decided there must have been a tiny vacuum leak somewhere, probably in some rubber part.
Sep 03, 2009 | Kitchen Appliances - Others
Water Reservoir Logo
49 people viewed this question
Top Exo Terra Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Exo Terra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
