Question about Dell Inspiron 1525 Notebook
Can't pair my HBH-PV705 bluetooth headset with my laptop
I want to use my HBH-PV705 blue tooth headset to talk through skype. My laptop has blue tooth included and it is turned on, however I do not know what to do for it to recognize the headset
In a tutorial in the sonyericsson webpage says that the headset is pre-paired to be used with USB dongle, since my laptop has bluetooth I guess I don't need one. I asked to sony ericsson's mexican support team and they said I "only" needed to download bluesoleil, but I was wondering if this is necessary.
  • 702 Answers
You need to have a bluetooth stack installed, so that you have "bluetooth places" available, where you can link up the headset.
A good instruction (for XP) is shown here.
Bluesoleil is definitely a good option.
Posted on May 21, 2009
I am using xperia X10...and i want to connect to my HBH-GV435 bluetooth to this phone..but the HBH-GV435 blue tooth is already paired with some other phone.so i want to reset the bluetooth and connect it...
Headset-
1. Make sure the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
2. Press and hold the On/Off button for at least five seconds, until you hear a long high-pitched beep and the light flashes red and green. The headset is now in pairing mode.
3. If your phone supports auto pairing, press "Yes" when the question Add device? appears in your phone. If it doesn't, continue with the next step.
4. Prepare your phone in accordance with the phone instructions for adding a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
X10-
1. From the Home screen, tap the applications bar.
2. Tap Settings > Wireless controls > Bluetooth settings.
3. Mark the Bluetooth check box.
4. The phone starts to search for the device. Make sure that the device is in pairing mode. If needed, tap Scan for devices.
5. When the device becomes visible in the Bluetooth devices found list, tap to select it.
6. If needed, tap the text bar to enter the passcode (0000 by default) and tap OK.
7. You can now start using the paired Bluetooth device. The status of the pairing and connection is shown below the name of the Bluetooth device in the Bluetooth devices list.
Good Luck!
Mar 23, 2011 | Sony Ericsson HBH-GV435 Bluetooth Headset...
I am connected bluetooth device HBH PV705 in computer windows 7 . Device not connected bluetooth driver (bluetooth peripheral Device) not updated. please help me, wat can update plz send sit link
run microsoft updates on your computer 1. control panel 2. system and secruity 3. windows updates f that doesnt work to the manufators website and download the date drivers hope this helps
Jan 06, 2011 | Sony Ericsson HBH-PV705 Headset
N97 connectivity problem with bluetooth HBH DS 200
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 08, 2009 | Sony Ericsson HBH-DS200 Stereo Bluetooth...
Sony blue tooth hbh-pv703
you need to press and hold the buton until the light stays on to get into pairing mode, when on, go to your phones bluetooth settings, search for bluetooth devices, then when it finds the headset a code will be requested, this is 0000, enter this and the light will flash intermittently telling you its paired with your phone.
Sep 03, 2008 | Sony Ericsson HBH-PV702 Wireless Headset
I cannot pair my Nokia N95 with HBH-608 Akono headset
Press and hold down the headset volume key in the centre. Hold it for about 5 sec. The led will now flash on/off in red. This is the pairing mode. Set your mobile phone to blue tooth discovery mode,until it finds the headset, key in the pass key, 0000. It should now work. You may need to set the phone to select the headset as an automatic connection so it connects whenever it is on and in range.
Jul 15, 2008 | Sony Ericsson HBH-PV705 Headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
Jul 14, 2008 | Sony Ericsson HBH-610a (Auto Pairing)...
Please need help urgently
You should press both + and - button on your head set and wait until green light turns into red.
May 13, 2008 | Sony Ericsson HBH-PV705 Headset
Hbh-pv705
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Nov 27, 2007 | Sony Ericsson HBH-PV705 Headset
Pairing
1) Make sure headset is off. 2) Press and hold the answer button until the light flashes green and red. 3) If it only flashes green, press and hold both volume buttons until the light lashes red and green. 4) It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000. 5) All done.
Feb 24, 2007 | Sony Ericsson Universal Bluetooth...
Dell Inspiron 1525 Notebook Logo
442 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
