Question about Gateway DX Computers & Internet
How to remove exterior card cover so i can install a new card
  • 38 Answers
Dear William,
Best practise: wear an anti-staic wrist-band! Leave machine plugged in to power but make sure that power is switched OFF at wall - (this will ensure that the machine is safely 'earthed'. . Open box cover - there are usually release button(s) to do this. Once computer box is open, connect anti-static wrist-band alligator clip to bare frame. The PCI-card covers are usually attached by one screw/nut: UNDO. Remove slot-cover. Insert new card into PCI-slot. Make sure it is home & replace locking screw. Remove anti-static clip. Close box. Power-up & let Windows find/install new device. I hope that this helps - 'b'ye - Bruce.
Posted on Apr 28, 2014
What is the secret to install seat in the rear?
Lift up the rug in front of the seat to expose the bolts holding the lower seat cudhion.
Jun 21, 2014 | 2010-2011 Toyota Prius F 50/50 Bucket...
It "popped" a circuit breaker
NORMALLY THERE ARE SCREWS TO REMOVE TO ACCESS A PANEL TO REMOVE THE LIGHT BULB. IF THERE ARE NOT, THEN THE EXTERIOR COVER MAY NEED TO BE REMOVED TO ACCESS THE LIGHT BULB. THIS EXTERIOR COVER HAS SCREWS.
MAKE SURE YOUR CIRCUIT BREAKER IS OFF BEFORE YOU TRY TO REPLACE THE BULB.
Feb 20, 2011 | Ovens
Ford expedition side mirror (instalation giude)
SECTION 501-09: Rear View Mirrors 2003 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel —Expedition Removal and Installation
NOTE: Left front door shown, right front similar.
  1. Remove the door handle bezel.
    • Use service notch.
  1. Remove the window control switch plate.
    • Use service notch and disconnect the electrical connectors.
  1. s3j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    Remove the two bolts and three screws, and remove the door trim panel.
  1. Remove the weather shield.
  1. Disconnect the exterior mirror electrical connector.
  1. Remove the exterior mirror.
    • Remove the nuts.
  1. To install, reverse the removal procedure.
    • Install top nut first.
Exterior Mirror Motor Removal and Installation
  1. Position the mirror glass to obtain a gap at the top edge of the mirror and carefully pull the top edge of the glass away from the mirror housing.
  1. Disconnect the heated mirror electrical connectors.
  1. Remove the exterior mirror motor screws and exterior mirror motor.
    • Disconnect the electrical connectors.
Oct 26, 2009 | 2003 Ford Expedition
Cannot connect to my dsl service they say i have a bad network card or adaptor what is it and how can i fix
The network card also know as a "NIC" is installed inside the PC.
You can change it by purchasing a new one.
Unplug the electrical plug before removing the cover of the PC.
Locate the NIC by following the Cable from the DSL modem, that is the card you want to replace.
Unplug the Cable from the modem, remove the screw located top back of card.
Pull up gently on the card to remove it from the slot and replace with the new one. You may have apply gentle downward force to seat the card.
Plug back in the Cable to the modem, replace cover, plug back in the Electrical supply and start up the computer. The system should atomatically find the card and install the drivers for it.
Sep 05, 2009 | HP Pavilion a430n PC Desktop
Whatis the procedure to replace the driver's side on 2005 Freesty
2005 Freestyle/Five Hundred/Montego Workshop Manual
  1. Remove the exterior mirror trim cover.(on inside of door)
  1. Remove the 3 exterior mirror nuts.
Jul 23, 2009 | 2005 Ford Freestyle
Replace left front door outside handle pot metal tip broke off
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
  1. Position the watershield aside.
  1. NOTE: The tie strap does not need to be reinstalled.
    If equipped, remove the tie strap from the anti-theft guard.
  1. Remove the screws and position the anti-theft guard aside.
  1. Release the clip and disconnect the exterior door handle actuating rod.
  1. Remove the anti-theft guard.
  1. Remove the exterior door handle screw.
  1. Remove the exterior handle actuating rod.
  1. Remove the exterior door handle lock cylinder cover.
  1. Remove the exterior door handle.
Apr 25, 2009 | 2001 Ford Escape
Installing exterior driver side and passaner side door handles
I found this on another page, hope it helps:)
Remove the plastic cover behind the door handle assembly by removing one black 14mm nut from just above the door handle, and 1 screw (usually phillips) from the bottom of the plastic cover.
Remove linkages from lock cylinder and door handle assembly. Use a small flathead screwdriver to slide retaining clips forward, and linkages will come free.
Remove one black 14mm nut from the very top of the door handle assembly.
Remove one phillips screw drom the bottom of the door handle assembly.
Door handle assembly should now come free by pulling out slightly at the top, and pulling upwards.
Transfer lock cylinder and key minder light (if applicable) to new door handle assembly. Lock cylinder is retained by a single TORX bolt.
Reinstall in reverse.
TIP: If you lose or damage any of those black plastic coated nuts, order new ones. They are GM p/n 10067214 and should be around $0.58/each. There are two on each door.
Mar 02, 2009 | 1995 Pontiac Grand Prix
2006 ford focus driver side mirror (electric)
Not that hard on this model.Here is a pic of the mirror and the removal and installation proceedure.
http://i253.photobucket.com/albums/hh43/chuck943/N0025797.gif
    1. Release the retaining clip.
    1. Disconnect the exterior mirror control switch electrical connector.
  1. Remove the exterior mirror bolt.
    • To install, tighten to 11 Nm (8 lb-ft).
  1. If equipped, remove the exterior mirror screw.
    • To install, tighten to 2 Nm (18 lb-in).
Mar 02, 2009 | 2001 Ford Focus
Replacement of Mirror/Assembly, 2004 Ford E350 Super Duty
NOTE: Aero mirror shown, dual arm similar.
Manual mirrors
  1. Remove the mirror sail cover to gain access to the exterior mirror retaining nuts.
Power exterior mirrors
  1. If equipped, remove the front door speaker.
  1. Remove the front door watershield.
All exterior mirrors
  1. Remove the rubber plugs and dust shield.
  1. Disconnect the electrical connector(s).
    1. Disconnect the power exterior mirror electrical connector.
    1. If equipped, disconnect the heated exterior mirror connector.
  1. Remove the nuts and remove the exterior mirror.
Jan 08, 2009 | 2007 Ford E-350 Super Duty Length XLT
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Computers & Internet Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
