Question about Watches
How do I reset the millisecond hand used in the stop watch function on my nixon Ride SS watch?
I just reset the chronograph second hand to the 12 at the top of the dial but now in the small dial directly under the 12 which counts milliseconds as the stop watch is started resets every time to a little past the 1 on the dial opposed to the proper spot at the 0. How can I fix this?
    Scholar:
  • 102 Answers
Try this:
Resetting Chronograph Hands:
Note: Some Nixon watches come equipped with a "screw-down" crown; the crown must be unscrewed by turning it counterclockwise before it can be pulled out)
1. Pull the crown all the way out to position 2.
2. Push the crown in slightly to position 1.
3. Push top pusher button to advance the second hand to line up with the 12:00 position
4. Push the crown back in. (Make sure it is screwed in if it is a screw crown)
Posted on Jan 02, 2014
SOURCE: SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Posted on Oct 02, 2007
jerryg50
  • 1689 Answers
SOURCE: Small dial on the watch face that counts the minutes won't return
Check in the instructions if there is a way to re-sync the hands. For some models of watches the hands are able to be calibrated.
It is also possible that the watch has a problem. Either the dial hand is not properly seated on to its axel, or the drive gear that is under the axel skipped a tooth. You will have to find someone who can service watches to fix this for you.
Jerry G.
Posted on Nov 21, 2008
SOURCE: chronograph hand does not reset to 0 (12 o'clock)
fake
Posted on Jun 22, 2009
ONECCO
  • 3 Answers
SOURCE: Just had battery changed in my Tag chronograph.
I love these watches, don't you?
Posted on Aug 16, 2009
escapement
  • 2334 Answers
SOURCE: I have an accutron and i want to reset the my
No need to go to the shop as you can reset chrono hand yourself. Read manual and follow instructions. If you don't have manual, try this: Pull out crown and then push the button and hold it. If this does not work, try push and hold the button whilst other one is held pushed. In short terms - try to use as many different combinations as you can and you will find which way is right.
Posted on Jan 09, 2010
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
Pulsar Chronograph 100 m - The second hand on the left small dial (not the sweep second hand of the stop watch) has begun moving erratically. It appears to move for two counts and pause for three and then...
If your watch is solar powered the second hand performs this characteristic when it's in need of a charge. Try placing your time piece under a bright light for short time or in direct sunlight and see if this helps you with your problem.
Jul 21, 2011 | Pulsar Chronograph Watch
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
Feb 28, 2011 | Fossil Watches
Bulova Marine Star with chronograph. The minute hand of the chronograph resets to the 'one minute' location, not the top of the dial. I tried pulling the dial out and pushing the 'A' button and let the...
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
Nov 14, 2010 | Bulova Chronograph Marine Star #96B99...
Stopping after 12 or 24 hours
Read your manual carefully and you will notice that the big, tall seconds hand is part of chronograph function. So, by pushing upper button you are actually engaging chronograph. This puts more strain on movement gears and consumes more battery power. When your watch is in normal timekeeping mode, the small seconds hand is counting seconds, not the big one which should be steady pointed at 12. I would recommend to put a new battery in your watch, reset it and start using it as described in users manual. You can download users manual here: http://www.oakley.com/customer-care/support/watches
Rate me, plz.
Jan 10, 2010 | Oakley Detonator OAK0530 Wrist Watch
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
Cant set the second hand to move
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"]
To start/stop this, use the top button (Button "A").
To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
The "second" hand is the small dial at the 9 O'clock position.
In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
Nov 11, 2009 | Pulsar Chronograph Watch
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Watches Logo
274 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
