Question about General Electric Dryers
Ge cycle electric dryer model number dde7200ralwh
I have a GE electric dryer model number DDE7200RALAD. It overheats with the rear (inside) of the dryer becoming red and inside and outside of the dryer hot. What may be the cause and how can I fix it? Is it worth it?
    Problem Solver:
  • 6 Answers
Take a neddle and put it in your reset button now you will lose your games but it worth it
Posted on Jan 02, 2014
  • wikkedwicky Jan 02, 2014
    whops it posted to the wrong post :/ delete if possable
4 Suggested Answers
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
  • 126 Answers
SOURCE: dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Posted on Jan 11, 2009
  • 71 Answers
SOURCE: GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Posted on Dec 21, 2008
What can cause an electric GE dryer to not start? Model number DCVH680EJ1WW. cogtinuity with motor switch, door switch, high limit fuse, thermistor & no cogn. with the thermodisc or heating element.
As a repair technician, just came across this crazy situation with GE / Hot Point / Moffat machines several times. It is all made by GE corporation.
The Dryer is not starting because your cycle selector knob is broken inside and it is just turning without turning the timer selector.
GE corporation machines are good. But those damn chinese plastic knobs break from inside. I have driven 50 km to find out the knob is broken. I had to charge the poor customer.
Apr 15, 2015 | GE Dryers
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
GE Model DDE7200RALWH squeaks like a metal on metal sound.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | GE DBSR453EBWW Electric Dryer
Feb 27, 2009 | GE DBLR333EE Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Ge dryer
Jim; without the model number it is hard to give specific advise. (model number is usually on the frame just inside the door) To open top, try pushing a putty knife in the seam between the dryer front and the dryer top, a few inches in from each side.
Nov 06, 2008 | GE DBSR453EBWW Electric Dryer
Year of dryer
INSIDE THE DRYER DOOR IS WHERE MOST MODEL NUMBER ARE OR ON THE TOP BACK OF THE DRYER HEAD,THANKS
Jul 23, 2008 | GE Dryers
Dryers Logo
222 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
