Question about Gateway DX Computers & Internet
How to remover outer card cover on gateway 4870 so i can install a video card?
3 Suggested Answers
  • 59 Answers
SOURCE: video card removal
Okay first things first make sure you have unlocked the card from the case. Most Gateways have a card lock on it. Once it is unlocked just pull the card out, sometimes they are hard to pull out but you can get a small screw driver and pry up at the case side and slowly work it out.
Hope this helps.
Posted on Feb 28, 2009
lars_olsson6
  • 3400 Answers
SOURCE: removing expansion slot cover Packard Bell
what do you mean ? do you mean the back the computer.remove the electric cord shoot down PSU. no lights on the motherboard.lay the computer down left side up remove the side should be easy. now you see the videocard now replace it whit a new.be careful it can sit tight,and has a klaw in the front so be gently.
Posted on Apr 04, 2013
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
New video card old motherboard
The new video-card should have come with a CD-ROM, containing the necessary device-driver software to support the device.
Or, from the manufacturer's web-site:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
download the device-driver for Windows XP Home/Professional, and install it.
Apr 10, 2010 | ATI RADEON HD 4870, PCI Express Video...
I have 4870 installed. i want to activate Second
Running two ATI cards is CrossFire not SLI, and no, you cannot run those two cards together. I am assuming you are reffering the the Video game Second life. The 4870 is still a beast of a card, I find it next to impossible it wont run the game. Make sure you have the latest CCC driver from game.amd.ati.com
Mar 14, 2010 | ATI RADEON HD 4870, PCI Express Video...
Drive ct 4870 plis
http://support.creative.com/Products/product_list.aspx?catID=1&CatName=Sound+Blaster#
Select you model and download the driver.
Mar 01, 2010 | Gateway Sound Blaster CT4870 Sound Card
My desktop gateway 3 series does not have a video card.....I would like to add one....is it hard to do so ??I want to buy a geforce 9600 or greater...
It is not so difficult as it seems to be.
First ensure that your computer meets the system requirement for installing a particular Video Card. You can get these details on the box of that card.
Once you are ready with all the details and the compatible card, follow the instructions as under:
  1. Turn off your computer and disconnect the power chord
  2. Open the Cover of your computer Tower.
  3. Disconnect the monitor cable from the Onboard VGA
  4. Locate the compatible card slot.
  5. GEForce 9600 would require a pci express slot
  6. Match the notch on the card with the Card slot and insert the card with a slight push.
  7. Fix the card to cabinet with a screw on top
  8. Connect the Monitor cable to the newly installed Video card
  9. Close the cover
  10. Connect the Power cable
  11. Restart the computer
  12. Your operating system will detect the new Video card and prompt you for drivers
  13. Installed the necessary drivers from the CD provided with the Video card
  14. Finish the installation and reboot the system
That's it you have a new Video card installed !!
Please let me know if you need any further help in regards to this.
Thank you for choosing Fixya
Oct 12, 2009 | Gateway GT5220 PC Desktop
Gainward HD 4870 x2 2048 Golden Sample-Motherboard compatibility
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3983992&CatId=3495
Jan 23, 2009 | Gainward Computers & Internet
INSTALLED EAH 4870 DARK NIGHT GRAPHICS CARD ON MY HP COMPUTER
does the video card got a HDMI port? in case if you are not using that, you can disable it from BIOS.
Mentioning your mobo model number/sound device would help us to understand and provide a better fix.
let us know the results. thanx
Jan 20, 2009 | ASUS EAH4850/HTDI/512M RADEON HD 4850...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
