Question about Furniture
Vibradorm set up instructions for remote operation
How do I reprogramme my vibradorm remote for bed
Just put upside down, pour a gallon of gasoline over it, and use a cigarette lighter to test the condition.
Aug 21, 2016 | Televison & Video
Uc7084t. Where can I get operating instructions?
Rotation may be selected by a switch on the side of the housing beneath the motor.
Mar 31, 2016 | Televison & Video
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Remote control instructions
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 19, 2014 | Televison & Video
Need operating instructions
Set-up instructions are too much to type in, and it is not practical. . If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy
Nov 05, 2013 | Universal Televison & Video
I lost the instructions for operating my 3300 one for all remote control. Please help me program my Toshiba tv so I'll be able to operate my tv set.
Turn on your Toshiba TV. On your remote, press the TV key. Press and hold the SET key depressed until the red LED blinks twice, then release it. Press the 0, 1, 5, and 4 keys. Point your remote at the TV and press the POWER key. Your TV should turn off. If not, repeat the programming routine pressing the 0156, 0060, or 1256 keys
Oct 03, 2013 | One For All URC-3300 Remote Control
I lost the papers that tells me how to set it up sony rm-v210 remote control
Here ya go. Heres some brief instructions and a link to sony for the codes and full instructions
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button until the SET indicator lights up.
  3. Press the appropriate component select button for the component being set up.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENTER button.
  7. Point the remote control at the component and press the POWER button.
NOTES:
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
go here for more information http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210
Oct 17, 2010 | Sony RMV210 Remote Control
TEVION TV does not work with a universal remote control
You will need to set the remote control to match the TV first. You can't just point and go...You will need the operating instructions for the remote control to be able to get the code for the TV, and the instruction sheet will also tell you how to set it. If you have lost the instructions, I suggest you chuck it, and buy a new one. They are very cheap these days. But before you decide which one to buy, check and make sure that it is suitable for your brand of TV...Please don't forget to rate this answer for me...
Feb 22, 2010 | Televison & Video
Philips universal remote codes
For the universal remotes, most of the models have their own code proprietary set. There is no industry standard. You must look in the romote's instructions to have the proper code settings.
Not all universal remotes will work with all models of TV sets. The combinations of the protocols for the codes are in the many thousands!
You will find that with the universal remotes they are very limited to accessing the features in the set. The universal remotes are only good for the basic functions. You will need the original remote to do any serious operations and to access the internal menus of your set.
Call the manufacture support for your set to find out how you can order the original. You would be better off.
Jerry G.
Aug 07, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Furniture Logo
166 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
