Question about Mth 30-11028 Wood Water Tower
I bought a used dMTH water tower 30-11028 and the gear box does not work correctly.
I need the wiring diagram for the motherboard which I am replacing with a new motherboard
MOST of the time there will be a diagram in the booklet that comes with the new motherboard. If you bought it second hand or the booklet isn't in the box I will need the make and model board you are using to put into the unit and the tower specs. That way I can be 100% on the diagram.
Hope this helps.
Mar 15, 2016 | Computers & Internet
What makes my 2009 santa fe gear shift sorta stiff to move
Hi
This condition is usually caused by the transmission gear shift tower
seizing up in the inhibitor switch. To correct this, the gear shifter cable will have to be taken off at the transmission end which is fasened to the shift tower. Then remove the inhibitor/range switch and unseize the shift tower, working it back and forth with antiseize lub. Once the tower is cleaned, lubbed and has free movement, install a new range switch and reinstall shift cable if it is okay. Note: reinstall range switch in the same position as the old part so the start settings for park and neutral are good.
Feb 22, 2015 | Hyundai 2009 Santa Fe
An error f 17 displayed on the screen
F17 means insufficient water supply. It could be the water tank is not seated correctly. But it may be the filter behind the tank is blocked. Does it come on all the time .. or just with coffee or Hot-water ? If it comes on with just one then it may be that the coffee or hot-water pump is defective. regards
Sep 28, 2014 | Miele CVA4070 Coffee Maker
Chevy cavalier gear shifter
if it is s manual box remove the gear lever tower from the top of the box and see what damage was done to the bottom of lever and/or lever pivot pin in the tower. Remember normal gear boxes require a gentle shift to allow the syncro rings to work properly and if you want to do racing changes get yourself a specially built box.
Jan 02, 2014 | Cars & Trucks
I just bought the Honeywell Quietset 8-Speed tower fan (black and silver on top). I installed it correctly but the fan is extremely loud and squeaky and can hear the inside pole that rotates the fan, even...
STOP! Before you take anything apart, turn fan upside down and find the large plastic "screw"(cord passes through it)that secures the fan to the pedestal. Is same color as unit. Loosen it and see if squeaking stops. Worked for me!
Mine was driving me nuts and I was prepared to return it to store.
Aug 30, 2011 | Honeywell Comfort Control Tower Fan -...
Bought a 36" oscillating tower fan model FZ10-9LR
this happen to me one i just went in bought new fan took the good remote out and gave them back the bad one brought it all back and got my money back.good luck
Aug 05, 2011 | Hampton Bay Dryers
Navigator only turns one way, twisting up the line
Try one of these soultions. If you try these suggestions and it still doesn't work correctly, let me know and I will offer some different ideas. With this brand of pool cleaners, troubleshooting is usually pretty simple.
1. You might have an improper water flow that is causing your trajectory to falter. To remedy this, check your water flow with a flow gauge and adjust as necessary. If you have too little or too much pressure, you cleaner will not move correctly.
2. Look for a blockage in the navigator throat. If you see one, remove it. A blockage on one side could cause the cleaner to only turn in one direction.
3. Check for worn shoes and wings. Replace if necessary.
4. Check and clean the rear screen.
5. Check to make sure that the gears are clear and they they rotate smoothly in both directions.
6. Clean, repair, or replace the gear box.
7. Check turbine and spindle gear assembly, as well as all connections, and make adjustments as necessary.
May 05, 2010 | Hayward Navigator Pool Cleaner
My oscillating fan has stopped oscillating how can i fix this
pls check first if the mode was properly set, or if not follow the manual you own from the first you bought the item. or try to unplug the item and open the back panel look if the gears is loose or broken.
Jun 30, 2009 | Black & Decker BDTF1010B Tower Fan
How does one change air filter in 2002 VW Passat 1.8T?
Its located on the drivers side just behind the battery and in front of the strut tower, a black square box with a black round plastic tube going to it, remove the top cover and you will see the square air filter inside.
Mar 20, 2009 | 2002 Volkswagen Jetta TDI
Mth 30-11028 Wood Water Tower Logo
Top Mth Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Mth Toy Expert? Answer questions, earn points and help others
