Question about Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea
Power shuts off when i sit on the scooter
Cable running from the controls to the rear left wheel just hanging loose. I reattached it. Some on the plastic casing is rubbed off. Scooter still wont run and when I am sitting on it it wont come on orit does then shuts off. I suspect the brake cable is not attached properly.
  • Shoprider Master
  • 1,263 Answers
Hi, it's only a loose connection or bad connection, pinpointing it will be harder, now turn over the scooter and check the wiring connections
from the battery connector to the controller mounted under the floor board, the best way is to have the scooter running while you move varoius cables but be careful of the wheels etc you will need someont to help you, take care...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jan 05, 2014
  • 61 Answers
SOURCE: don't have a troubleshooting book. replaced
Shoprider scooters beep when there is a problem with them. Firstly, are the batteries ok? You can obviously tell this from your battery meter on the tiller (although its not uncommen for these to fail and give false readings on shopriders). If batts are ok, you need to determine what type of main contol box is on the scooter. This will be located at the rear of the scooter, underneath the plastic shroud. Remove the seat, then the plastic shroud, to get to it. You may need to dis-connect a plug to the rear lights. If you can see a black box with ridges on, with lots of wires entering it, and it has the word Pihsiang written somewhere on it, theres a good chance it will be this that is at fault (although not difinately, could be a wiring loom problem). These boxes have no diagnostics built in, so they beep constantly when at fault. If its a different type of control box that you see, it may beep a certain amount of times to indicate what the problem is. Count the beeps and refer to your owners manual or a dealer to determine the fault. Hope I've been of some help to you.
Posted on Mar 29, 2010
  • 177 Answers
Hi. Some shoprider machines have fault codes and most dont. I will try and cover what the main faults might be.
Free-wheel lever in the wrong position. Faulty brake coil. Resistance should be about 50 ohm's.
Stuck brush in the motor stopping the motor from operating. Check the resistance through the motor, should be approx. 1 ohm.
Speed lever ( wig wag ) not in central or neutral position or faulty..
Battery voltage too low or battery leads faulty.
Good luck. Neil.
Posted on Jun 01, 2010
  • 692 Answers
SOURCE: sprinter xl. Batteries old but pass
Could be a throttle pot problem and /or a speed control pot problem one or both could be dirty or have a bad spot on the pot. If you can live with it use it until you get a flash code trip on the console. Hope this helps
Posted on Aug 21, 2010
  • 692 Answers
SOURCE: my echo 3 scooter beeps as soon as I turn on the
Boy I hate working on scooters too many things can go wrong to make them not work. First make sure you are not in freewheel Make sure the lever at the rear of the scooter is in drive position. and you can't push the scooter easily without powering it up. If its not in freewheel then the problem could be a throttle pot problem or a speed pot problem or even a motor problem and there is no way I can troubleshoot your problem in this format. I would suggest that you have your provider check it or if Medicare paid for it have a repair service fix it for you. Sorry can't really give you a precise answer on whats wrong Good Luck Hope this helps
Posted on Nov 19, 2010
wcdoc1953
  • 278 Answers
SOURCE: Scooter needs to be run forward before it will
Sounds like you have a bad motor brush or motor.
I would block up the scooter, remove the seat and rear shroud and inspect the motor while it is running up on blocks. Use a rubber band or tape to hold the throttle lever. Listen for unusual sounds like a whine or growl from the motor, brake or trans-axle. Inspect and wiggle all the wiring, checking for loose connections at the batteries, controller, and front to rear wiring harnesses. See if you can duplicate the problem using a rubber mallet to simulate a bump.
Use a digital voltmeter to check the motor. The brake should read between 40 and 60 ohms and the motor coil resistance should be less than 1.2 ohms. You should pull the caps on the motor brushes and inspect for wear, burning , and melted leads. I have seen the motor brush hang up on the armature in one direction and not the other. You might try rotating the brush 180 degrees on installation to see if this is the case. Large carbon build up inside the motor from brush wear can also cause this. Blow out the brush dust with compressed air when you have the brushes out. There could be another problem related to what you describe and is associated with the throttle potentiometer. If there are dead spots on the potentiometer you could experience the same forward and reverse problem.
The first solution involves replacing a motor/brake, the second involves replacing the throttle potentiometer. Both repairs are straightforward and within the expertise of a good do-it-yourself-er. The parts should be available on-line at a discount. You will save considerable by doing your own labor. Hope this helps.
Posted on Dec 16, 2010
H0w to remove rear wheel?
Take off nut, washer gently tug left/right while pulling. They can sometimes be difficult. You can place penetrating oil at key and shaft but remove all of it before placing on a new wheel. Be careful not to loose the shaft key.
Aug 23, 2014 | Pride Go Go Elite Traveller Plus 3 Wheel...
No power post tilted backwards
Check the cable leading from the joystick control to the base of the chair. You more than likely disconnected that cable.
Aug 16, 2014 | Golden Technologies Alante Jr GP-200...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Squeeking
That is strange because both rear wheels as they are connected directly to the trans-axle.I would block up the rear of the scooter so the rear wheels are off the floor, run the scooter,does it still squeak. If it does still squeak its probably the braking mechanism or the freewheel mechanism. I use allot of silicon spray in this area. I use my scooter outside allot, moisture gets into this area and can cause problems. I use pure silicon spray. WARNING; do not use WD-40, it will dissolve some plastics. Also wd40 gets sticky after awhile. Pure silicon spray wont harm anything and is EXCELLENT lubricant. Most scooters trans-axles are hard mounted to the frame, they have no suspension, maybe yours does have some sort of suspension, If it does spray all the joints with silicon. Hope this helps
Jul 16, 2012 | Pride Mobility Victory 3 Wheel Electric...
Rascal 600T motor gets hot.
Check the electric brake its most likely not disengaging from the motor case causing the motor to strain and overheat. You can unscrew the brake assembly from the rear of the motor and check to see if the brake pad is free and moveable If you can support the rear wheels off the ground and engage the throttle you should be able to hear and see the brake pad release. You can drive the scooter with the brake off the motor but do not disconnect the brake wiring. The scooter looks for that connection to work if it can't find the brake then it will flash and won't operate. now if you do hang the brake off the motor remember you do not have brakes and the scooter can roll backwards when going up ramps or on hills. You will have to replace the brake assembly and reattach it to the motor to have brakes
Hope this helps you
Apr 05, 2011 | Health & Beauty
My 3 wheeled mobility scooter cuts out almost every time I turn the handle to the left. I think it may have a kinked wire.
This typically happens when the front to rear wiring harness has a damaged internal wire or wires. The front to rear harness runs from the front control console, down through the tiller (T part) through the front wheel frame and angle adjustment collar, and through the bottom frame to the controller. There is a wear area of the wiring at the front bearing of the steering tiller. There are 8 or more wires in a covered jacket that run through this area. Over time they rub and get pinched or kinked and broken. The test for bad wiring is exactly what you describe. Usually the broken internal wiring cannot be seen.
The best solution is to replace the entire front to rear harness with the new connectors at each end. The harness is relatively inexpensive and labor should be about 1 hour. Hope this helps.
Jan 30, 2011 | Electric Mobility 3 Wheel Motorized...
Axle makes a noises going forward only sounds like a bad bushing
there is no bushing on my rear wheels axle albeit an older scooter...wheel runs metal to metal on the axle and so...remove wheel and clean an grease the axle an replace the wheel.... probably wouldn't hurt to run a greasy rag back and forth through the wheel a time or two too...Sometime next week. The Maintenance Dude here @ Big Muddy River Apartments will be correcting a dry rear wheel on my old ole Golden Companion II. I had just acquired the thing and almost immediately after I sat on it to take it for a spin. The left rear wheel started acting up. Lucky my power chair guy does scooter repair too, and he told me no bearings in the back wheels. Its metal to metal and removing the wheel an greasing the axle should take care of it, and I havt'a say that was really admirable of him cause he could have clipped me for a service call and a grease job.....the end
Jan 15, 2011 | Golden Technologies Golden CompanioN II -...
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Won't move lite on battery fully charged
I had this problem with the Cosco 4 wheel scooter. It turned out that one of the primary power lines under the shroud (back housing cover) was loose. It was not disconnected -- just loose. Apparently the loose connection would support enough current flow for the diagnostic circuit, but not enough to move the scooter (similar to using too small of a wire gauge in its effect). Once the power cable connector was tightened down so that the cable would not rotate on the connector, everything worked correctly.
The same symptoms could also be caused by a faulty power cable. If you have access to a multimeter, test the resistance along each cable path. If a path has an unusually high resistance, compared to the others, start to look for problems there.
Apr 16, 2010 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Odyssey 4-wheel electric scooter - The following has happened twice in a 6 month period near the same geographic neighborhood location. While driving the scooter, which is fully charged and operating...
Always check the battery connections first because too many times it is a loose connection or battery bolt. it would happen more if you drive it a long distance, or up a hill and the controller over heats or if you are hitting a bump. when the controller cools down it drives again.
Mar 01, 2009 | Odyssey Drive 4-Wheel Scooter - Color Blue
Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea Logo
102 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
