Question about Saeco Vacuums
Mia steam cleaner troubleshoot
Assembly instructions are hard to follow
5 Suggested Answers
RockyNR1
  • 324 Answers
SOURCE: instructions for a kirby steam cleaner
Take a look HERE. It should help
Good Luck
Rocky
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: i bought my euro-pro steam cleaner
I have the manual in a pdf file. Email me and I'll forward it to you
Rich
Posted on Feb 23, 2009
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
small6363
  • 18402 Answers
SOURCE: Instruction manual for Little Yello Steam Cleaner
what brand name is the model BISSELLL/ SHARK/HOOVER/?
Posted on Nov 20, 2012
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
Sep 29, 2015 | Shark Ultra Steam-blaster Hard Surface...
Why does water pour out the back when I use carpet steam cleaner
Hey there! It sounds like your cleaner is leaking. That can mean an issue with your pump assembly. We recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jul 01, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How to clean out a hot spot steamer? clogged
Go to the hardware store near you and get steam iron cleaner and follow the instructions on the package.
Jan 20, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    My h2o mop won't steam. How do i fix it?
    If your H2O mop will not steam:
    1. Ensure you have followed the operating instructions.
    2. Ensure you have followed the troubleshooting instructions.
    If the unit fails to produce steam:
    3. Switch off the power at the outlet.
    4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
    5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
    Note: Unless the cone is submerged in water, the unit will not steam.
    Apr 21, 2012 | H2o TR220002 Steam Cleaner
    How to use my staem cleaner
    Follow the link below to download a copy of the User's Guide.
    http://www.bissell.com/searchresults.aspx?searchtext=25A3&searchType=search&mode=userguides
    The wood floor cleaner will work on your tile.
    Jun 17, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
    I purchased a Bissell steam cleaner demo, and I have no working instruction.
    Go to www.bissell.com and click on the customer service link and have them send you a copy. If you purchased the cleaner brand new and it had no instructions with it, they SHOULD NOT charge you.
    Mar 05, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Valve stem assembly
    Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
    Dec 29, 2007 | Vacuums
    Vacuums Logo
    22 people viewed this question
    Top Saeco Vacuums Experts
    JoeVacs
    Are you a Saeco Vacuum Expert? Answer questions, earn points and help others
