Question about Saeco Vacuums
Assembly isnstructions are hard to follow - Saeco Vacuums
  • 55 Answers
Identify each part -- don't skip any steps- start @ step 1.
Posted on Jan 02, 2014
Is there a more efficient way to clean the brush assembly on the max extract dual v other than running the assembly under water? The bristles are loaded with carpet fuzz and remains of doggy doo
Following is the procedure for removing the brushes.
  • Your cleaner is equipped with removable brushes. Follow these directions for changing brush assemblies or for easy cleaning. How to Remove To prevent possible leaking, remove Clean Water Tank and Dirty Water Tank. Set tanks aside. With handle in upright position, tilt cleaner back until handle rests on the floor. 5.3 Grab brush assembly and pull firmly.
  • The brushes can be cleaned under running water. ! CAUTION ! To reduce the risk of injury from moving parts, unplug cleaner before servicing.
See page 17 of the link manual for the details
http://hoover.com/file/594
Dec 10, 2015 | Vacuums
Tip
Dyson Hard DC56 or DC57 cordless vacuum cleaner - Getting started
How to assemble and use your new Dyson Hard DC56 or DC57 cordless vacuum cleaner. Our video also shows you how to attach and remove the wet wipe, and how to use the Double edge floor tool without the wet wipe for general hard floor vacuuming.
on Oct 04, 2013 | Dyson Vacuums
WHY IS IT SO HARD TO ASSEMBLE THE DIRT CUP INTO THE VACUUM
Good seal between the cups ensures that the vacuum cleaner has full suction. Check that there is no dirt or damage on the lip of the filter cup causing it to be jam up and be hard to assemble.,
Apr 08, 2015 | Hoover U5180-900 Vacuum
Hoover max extract leaks from end of upholstery hose
Hello! The nozzle/valve assembly, the white piece at the end of the hose that releases the solution may be clogged with build-up residue. Try soaking the trigger end in warm water for a few hours. If this does not help, the nozzle/valve assembly may need to be replaced. Order the nozzle/valve assembly by following this link. Search Results or order the complete hose assembly by following this link. Search Results
Hope this helps!
Jun 06, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My brush bar keeps falling down. We replaced motor but now the brushes don't spin.
Hi! If you've replaced the turbine & gear assembly and the brushes are still not spinning, a replacement brush-block assembly may be needed. The brushes counter rotate and need each other to spin. If a single brush is falling out, the brush assembly is broken. If the whole brush assembly keeps falling out, the drive pin shaft may be damaged. To order a replacement brush-block follow the link below.
Search Results
Hope this helps!
Jun 03, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
Brush doesn't spin
This model has Brush Control
The Brushbar can be turned off to protect rugs and delicate floors
You've either accidently turned the brushbar off or the belts broken
Apr 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
NEED WATER PICKUP HOSE ASSEMBLY FOR FH40000
All availble Hoover parts for the FH40000 can be found on usavacuum.com
Follow the link below to the site
http://www.usavacuum.com/category-s/86.htm
Mar 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My Hoover steam vac dual v's brushes will not spin and the square that the peg goes into wont spin either. There is suction but it is making a loud noise.
sometime when the brush is not turning their are less resistance to the motor, so it will turn allot faster than normal. The turbine gear assembly which connected to the brush assembly probably broken, all the gears are made out plastic and they can easily break,strip or worned over period of usage. the assembly cost around 20 bucks and it not that hard to replace and it not that hard to take it apart, just remember what goes where. I wonldn't surprise when taking the vacuum apart as you observed closely and inspect the brush unit and the turbine gear assembly you might easily spot what broken and need replacing. hope that help some; and if you don't want to fiddle with it, your local vacuum repair guy can probably do it for less than 40 bucks. you can go on-line vacuum parts.com
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Valve Stem Assembly for Hoover Steam Vac
Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
Dec 29, 2007 | Vacuums
Vacuums Logo
27 people viewed this question
Top Saeco Vacuums Experts
Are you a Saeco Vacuum Expert? Answer questions, earn points and help others
