Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
ECS 6100SM-M hangs on POST
Hi; It tries to POST but hangs right after the message detecting the processor comes up. I tried reseating components, cables, etc without success. Replaced power supply, no luck. Any ideas? Thanks
  • bryerpj May 28, 2009
    Hi; sorry for the delay. I've tried 3 different sticks with no luck in any slot.
  • 241 Answers
Check memory, remove or replace sticks of memory with just one piece in the slot closes to the CPU. Now try a power on and see if it boots. You have at lease one good stick of memory to boot.
Posted on May 21, 2009
Bios hanging when cpu check begins
U can try dropping in another cpu, and removing all peripherals except the memory and see if it recognizes it. If problem persists the anomaly lies within the cmos of the mo bo or the mo bo itself.
If the cpu is now recognized add the peripherals one by one till the problem reappears. The last item you added is causing the hassle.
Apr 02, 2015 | EliteGroup GeForce 6100SM-M Motherboard
My pc is hanging and when restart dont show disply and beeping ecs geforce 6100sm-m2
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
if faulty can affect your picture screen
a computer needs its connections to continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
if you need more help with this post a reply
hope this helps you
Aug 29, 2011 | EliteGroup ECS GeForce6100SM-M (1.0)...
I have Geforce 6100sm-mv will power on but no display and no post. The CPU is ran is running cd rom has power but no post at all, and beeps at all.
1.you possible have a power supply that is bad or a bad video graphics card ( which is internal to the board.
Try , if you have one or can borrow on a pci graphic display video card in the PCI slot and see if you have video. If you get a display you have a bad video on the mother board. windows should detect the card in default and you should be able see post if this is the issue.
Apr 22, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
After downloading drivers from ECS site for geforce 6100 sm-m i still do not have ethernet adapter. Also other pci bridge device is missing. In XP
since your not able to install the drivers..
Broadcom AC131 10/100 driver is the same as nforce 430/410
http://www.nvidia.com/object/nforce_nf4_430_410_winxp32_8.26.html
or
http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
then try installing Uniblue DriverScanner or Driver Genius Professional Edition so you can get all the other drivers for you motherboard
you can also try to update your bios only for ecs 6100sm-m mobo
http://drivers.softpedia.com/get/BIOS/ECS/ECS-GeForce6100SM-M-V10-10A-BIOS-070906.shtml
hope this helps..
Dec 31, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
Can cpu multiplier be set on ecs 6100sm-m mo bo?
Yes, I use AMD's program called Overdrive.
Be warned that increasing the mulipler also increase the voltage, don't go to high or you will have a smoked processor.
Apr 17, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Need help my computer got very high timming. if i play for some one game like counter strike, they movement very fast. my PC is : ECS GeForce 6100SM-M Proc AMD Sempron 3000+ VGA Geforce 7200GS/7300SE...
I would first try to upgrade your ram, i wouldnt want to touch a computer with less than 1GB of ram, and your only running 1/2 of that and playing a FPS game. Try to get another GB of ram, Newegg.com is a great place to shop for good prices and excellent customer service. If you only have 2 slots on your motherboard, you will have to take the 256mb chips out to replace them with larger ones. If that is the case, try replacing one of them with a 1GB stick.
Mar 22, 2009 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
ECS 6100sm-m
Download WD's software to test & setup drive. Try windows install again.
WD's link; http://support.wdc.com/download/index.asp?cxml=n
Mike
Apr 25, 2008 | EliteGroup GeForce 6100SM-M Motherboard
GeForce 6100SM-M Motherboard (no Audio )
I down loaded Realtek HD audio drivers from
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=685&DetailName=Driver&DetailDesc=GeForce6100SM-M(V1.0/1.0A)&CategoryID=1&MenuID=75&LanID=0
Oct 24, 2007 | EliteGroup GeForce 6100SM-M Motherboard
XP BSD....
What was the error message? (where it claimed that there was a problem with your HDD?)
Also, as you said that it is a homebuilt computer, there may be some components in the computer that don't work together. Maybe that is the reason it gave you the Blue Screen of Death!
Oct 16, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
452 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
