Question about RCA F19421 19" TV
RCA F19421 Stuck on video since switched from dishnetwork to cable
We switched from dish network to cable tv now my two older RCA are stuck on video. I have tried to set the tv to cable tv but it keeps switching back to video. The two rca tvs do not have a cable box anoter tv has the cable box. Not sure what else to try.
    Scholar:
  • 102 Answers
Some RCA TV's have a "video" option that requires you to use the original remote control to cycle up or down the channels.
Also, try unplugging the TV's from the power receptacle for 30 minutes....some times, that will cause the TV to reset.
With the power cord unplugged, manually push the power button on the front of the TV to discharge all capacitors.
Ensure the 30 minute is complete before plugging it back in.
Let me know if this works.
Thank you!
Posted on Jan 02, 2014
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
daniel719
  • 240 Answers
SOURCE: Cannot Switch over to AV Channel
you need an rca universall remote with you model number listed.
regards,
daniel.
Posted on Jan 11, 2009
SOURCE: rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Posted on Feb 27, 2009
  • 89 Answers
SOURCE: RCA Colortrak Stereo Monitor won't play DVD/Nintendo
The way you describe having your TV/DVD connected you wont see the picture in the regular channel line-up.
You will have to tell the TV to to switch to the video input. This is usually done by navigating the menu to the "input" and selecting video 1, video 2 etc
Failing that try changing to channel 00 ( just type 00 in remote)
Some sets will allow you to type in 02 and then hit the channel down button on the remote.
If you have the user manual it will give you the exact steps you need to take.
Posted on Mar 14, 2009
tvtek
  • 1284 Answers
SOURCE: I have an old RCA XS TV and cannot figure out how
Alot of the older RCA chassis required you to press 00, 91, or 92 to get to the external video input.
Posted on Oct 03, 2009
What is the satellite setting?
Hi my name is Mike Houston a Social Media Representative of DISH Network, if you are trying to find the input on your TV to view DISH programming, it will depend on the connections. If you are using RCA cables (red, white, and yellow) it should be on video 1 or video 2. By using the component cable (red, blue and green) it should be component 1 or component 2. If you have any questions please e-mail me; Michael.houston@dishnetwork.com.
Jan 08, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I just need a diagram to show me how to hook the dvd/vcr up to my television. I have Dishnetwork as well. I un-hooked and now I can't get a picture.
Not knowing the model of the TV its hard to tell you how to hook it up. Howeever let's assume that yu TV has an auido in and a composite video input. it it does is should have three RCA jacks on the back...one red, one white and one yellow.
Assuming Dishnetwork is being used as a analog video.
Connect the VCR/DVD player via a patch cable ( usually has three cable all color coded, red, white & yellow) Red and White section is used for the audio Left and Right. The yellow cable is video.
Connect the audio out of the VCR/DVD player to the audio input on the TV. Do the same with the videoout of the VCR/DVD to the TV may be marked "Composite Video". Now connect your Dish Network receiver RF Out to the TV. This should be a coaxal cable.
Now when you want VRC/DVD use your remote and select input. Some older TV's have the aux input just before Ch 2. Some remotes have an input button.
once you have aux inpsut selected turn on the dvd and play your movie to view Dish go to Ch 3 or 4 depending on how your TV and system is set up.
Again not knowing the model TV you have, this is a general hook up.
Thank you Let us know if it helps
Tom Miller
Broadcast Engineer
Sep 09, 2011 | Televison & Video
TV says Main no signal. Trying to hook up our Akai tv to the DISH network. Need help
Good afternoon! My name is Becki, with DISH. I hope that you have gotten this resolved, but if not, here are some steps to do so!
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. (The correct location for these on the back of the recever will have a TV 3/4 above it.)
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2) (The correct location for these on the back of the receiver will have a green TV symbol with a 1 in it.)
Please let me know if you need any further assistance!!
Becki Barned
DISH Network Customer Service
becki,barned@dishnetwork.com
Aug 03, 2011 | Akai LCT2715 27 in. LCD Television
I just recieved the Sylvania LC195SLX from my grandfather, it has no remote, but we are using dish network remote anyway, the channel is stuck on 5, and i can't change any channel or get a signal from...
Hello! I hope that you have gotten this resolved, but if not, here are some steps to do so. You can program the remote to the TV first and then use that for this, or you can use the buttons on the TV itself.
Remote to TV Steps:
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
527
733
632
Satellite picture back:
If you are using a coax cable, the TV needs to be on 3 or 4.
Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
Becki Barned
becki.barned@dishnetwork.com
Jul 13, 2011 | Sylvania LC195SLX LCD TV
I have a 322 dish receiver there is just too ports to hook to and i have ant.+ cable and sat. to hook to it anyhelp would be welcome. thanks
Heychuck68102, my name is Mike Houston of DISH Network and I was going over yourpost and I see where you want to connect a cable wire plus you're satellite. Ifyou have a TV that will allow for a RCA connection you can run the RCA cable tothe top red, white and yellow inputs and run the antenna directly to theTV/Antenna IN. Then you will be able to connect the cable to the TV CH ¾ input.I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/how-to-set-up.
Apr 16, 2011 | DISH Network 322 DTV Receiver
I have a zenith tv older model, and have dish network, i need to know how to hook it up and switch it over so i can play it
If you have an HD receiver you will want to use one of two types of cables; you can use component cables which have five ends red, blue, green, red and white, or you can use an HDMI cable which will have one flat connection. If you have a standard definition receiver you will want to use RCA cables these have three ends red yellow white. The connections will be labeled on the television as well as the receiver. Once you get this connected hit the input/source button on your TV set if you're using RCA cables you want the TV set to video 1 or video 2. If you're using an HDMI cable then set the TV to HDMI 1or 2 using the input /source button. If you use Component cables set the TV to Y/PB/PR or component 1/2.
Daniel Busa
Mar 09, 2011 | Zenith Z50P3 50 in. Plasma TV
I'm trying to hook up my dvd player & recorder but i can not get a picture on the tv. I put it on channel 3,4,60,73 like the book says
Hi donsol45my name is Mike Houston of DISH Network and I was reading over your post abouthooking up your DVD player to play. If you are using RCA cables that have Red,White and Yellow for tips. You can connect them directly to your TV and it willrun off your Video Input 1, 2 or 3 and if you're still having a problem please e-mailme. Michael.houston@dishnetwork.com
Feb 20, 2011 | DISH Network Televison & Video
How to connect a RCA HD56W58 56" TV to your cable box we have a dish network box and the only thing on the screen is input output please help
Try this link it should have all of the troubleshooting for this type of issue.
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
Dec 16, 2010 | RCA HD56W58 56" TV
Dish network remote code for RCA l26hd41
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
this web page has remote codes for dish network
to rca if can't find page do search dishnetwork remote codeshttp://www.satellitecompanion.com/Television/DishNetworkRemoteCodes.aspx
this web page has programing instructions
good luck ron
Dec 14, 2009 | RCA L26HD41 LCD TV
RCA F19421 19" TV Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
