Question about Spidem Trevi Automatic Espresso Machine
Spidem Trevi brewunit block
Brew unit block. I have pulled it out. Cleaned it, put it back several times and still get the same message!
  • 7 Answers
SOURCE: Gaggia Trevi or Spidem Trevi
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error message2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Posted on Jan 04, 2008
mirran
  • 515 Answers
SOURCE: spidem divina deluxe digital
I think the gear wheel in the machine is broken and have to be replaced.
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: How to Prime Spidem Trevi Combi Plus Espresso Machine
Open the steam knob on the side and make a cup of water (Tea).
Best regards
/Mirran
Posted on Oct 26, 2008
SOURCE: spidem trevi exclusive
you have probably removed the tray during the time the brew unit was transporting the coffee. by removing the tray you stopped the transporting unit in the middle of this process.
You can solve this by putting back the brew unit. Close the machine Do not put back the dump tray. Look into the machine, at the spot where the dumptray should go. There is a litte slot in the back. but put a little spoon or some smal screwdriver into this slot. You can hear the machine finish the transporting cycle. After that you can put back the dumptray and it should work again.
Posted on Nov 08, 2008
freetek
  • 5568 Answers
SOURCE: No power to my Spidem Trevi Digital Coffee machine
Although it may be a different problem completely, most of these failures are caused by a thermal fuse that has opened. They are positioned close to the heating element and serve to prevent fires in case the control of the heater element fails. Unfortunately, they often fail for no reason at all (except being poorly made in China) and are welded into the circuit (solder melts at too low of a temperature) making them nearly impossible to replace at home.
Posted on Feb 18, 2009
Brew Unit Blocked
open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Nov 25, 2013 | Saeco Royal Professional Espresso Machine
I have a Miele Coffee Machine (built-in) CVA 620-1. I got a message saying the brewing unit is blocked. I removed the waste unit, a procedure that has to be done before you can remove the brewing unit. ...
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Sep 14, 2010 | Miele CVA615 Espresso Machine
The machine is showing the brew unit is blocked but we have taken it out and cleaned it but this makes no difference.
Does the brew unit try to move at all? You can listen for the motor, or open the door panel and defeat the safety interlock while it's operating. (Be careful not to put a finger in there.) Then you can observe where the brew unit is getting stuck.
May 19, 2010 | Gaggia Syncrony Compact Digital Espresso...
Hi thanks for the imfo but just cleaned brew unit and greased all
The main board has failed.
This occurs when the brew unit is too tight and not lubed up.
It damages drive components on the main board.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Brew draw blocked
Ok if brew unit is displayed,the cause is the brew unit needs to be to cleaned of all old grease and coffee grounds.
Once cleaned you will need to regrease the big oring at the top of the brew unit,pretty much anywhere that moves needs to be lubed and the two smaller ones near the back of the dreg drawer.
In some cases a tight or siezed brew unit can damage the main control board.
Feb 02, 2010 | Gaggia Titanium Espresso Machine
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
My brewunit is blocked
Coffee fines and mineral scale build up in the brew unit filters and also in the creme valve. The pressure to pump water through the unit fails and the flowmeter tells the electronics that no water has flowed, it in turn stops all processes and displays "brew unit blocked" message. If you're handy, call Miele tech support. The'll walk you through how to remove the drainage cup screw off the left rear of the brew unit, get the brew unit out and return the gearing to home position. It's a 50/50 chance the gears will return or you will need a service tech to pull your coffee unit out and re-sync the gears to the electronics. That's of course if they didn't break.
This blockage is is prevented only by using the cleaning tablets and descaling tablets. Both need to be used as outlined in the instruction manual.
Oct 02, 2009 | Miele CVA615 Espresso Machine
Dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
Apr 10, 2009 | Saeco Royal Professional Espresso Machine
Brewunit blocked
It sounds like the brew unit is stuck with the platform tipped forward. This will prevent the dreg drawer from being put in or out. Your problem could be the result of a few things. Some you can fix, some may take more work. You can get the brew unit out by following the steps outlined on a partsguru.com, Brew group removal.
Dec 18, 2008 | Saeco Magic Comfort Plus Espresso Machine
Spidem Trevi Automatic Espresso Machine Logo
32 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
